Removing front seats
Which car? For the most part, they are all just 4 bolts that go into the floor pan. Remove them and the seat is loose. IF you are taking them OUT of the car, disconnect the battery and then remove the connectors under the seat - if you do it with the battery connected, you will trip the airbag lights. When you reinstall them, plug the connectors back in, and then reconnect the battery.
With the TSX, I pulled the pass seat with the battery connected, but I NEVER turned on the Ignition without the seat plugged in. It was a PITA to put it back in every time I wanted to check something with the key on : )
Thanks guys, well I was looking to wire the the seats for some monitors in the headrests and wanted to take the seats out so I could use some care. Do you guys usually wire the seats while theyre in or do you take them out. Also I have an 02 tl sorry for not specifying. Oh and thanks eldude I got the visors to work.
Most HR video installs are done with the seat in the car. But if I were doing a car for the first time, I'd probably take the seat out of the car and put it on a workbench.Then when I ran the wires inside a car, I'd have an idea of what the heck I was doing : ) (no, I havne't done that part before, just watched>..)
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
