remove speakers
Old Sep 4, 2004 | 07:02 PM
remove speakers
what are the steps to remove the front and rear speakers on a 2000 TL?
Old Sep 4, 2004 | 09:03 PM
NYZGREATST's Avatar
Sig Rho's Finest
take all the screws out of the door panel. pull out the door handle area towars the back of the car. and behind it you will see a metal rod that is held into place. remove the clip and then jus apply light force on the edges of the panel and the clips will release it. its kinda hard to visualize if you have never one this before.
Old Sep 9, 2004 | 02:50 PM
so the only srew is the one on the door handle?
thanks
Old Sep 9, 2004 | 08:37 PM
Rusky's Avatar
My baby's daddy
there is a screw on the door handle that you pull to unlatch the door (there is a plastic cover on it) and a screw on the arm rest / handle that you pull to close the door. Two screws. After you remove the screw on the pull handle, as tpatel explained, slide the whole plastic assembly toward the back of the car. The door linkage is then visible and you spin the little clippy thing around so the rod can come out from the top. Then just pull.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
polish_pat
Sep 25, 2015 12:24 PM
