Removal of stock sub - effects on trunk sub?
Old Oct 8, 2003 | 06:52 PM
bozzchem's Avatar
I've been toying with the idea of removing the stock sub to allow a "port" for the bass from my IDMAX.
Have any of you done so and did you notice a difference? Is this something you'd recommend?
Theoretically it would turn the trunk into a huge vented enclosure since there will now be a 9" or so hole going directly into the cabin.
I'm probably going to do it anyway just to see for myself but I'd like to hear what you thought of it if you've done it.
Thanks.
Old Oct 8, 2003 | 07:24 PM
TopGum's Avatar
I like it. One thing is you get a little more glare at night from the brake light. It lights up the mesh.
Old Oct 8, 2003 | 08:12 PM
bozzchem's Avatar
LOL, I'm sure the brake light glare is pretty....BUT I'm more interested in a difference in the output from my trunk mounted woofer.
Old Oct 9, 2003 | 07:55 AM
shawhite's Avatar
personally bozz i dont think you will notice a big difference unless you port your box thru that hole... i know i tried both ways when i first put my sub in and really did not hear much of a difference..
Old Oct 9, 2003 | 12:56 PM
fsttyms1's Avatar
you should hear a difference. try poping your center arm rest down once, it should be along the same lines
Old Oct 9, 2003 | 06:28 PM
bozzchem's Avatar
??? I lost you on this one.
Old Oct 9, 2003 | 08:26 PM
NSXNEXT's Avatar
He means open up the passthrough door in the back seat/
Old Oct 9, 2003 | 08:38 PM
bozzchem's Avatar
That's great for a one time deal. I'm looking for something that will make a difference full time. I can't use the rear pass through as a vent. I CAN remove the POS Bose sub and see what happens.
Maybe I'll just have to do it myself to see how it sounds both ways.
Thanks.
Old Oct 11, 2003 | 09:58 PM
TopGum's Avatar
Sorry, I was not very clear I like having the stock sub removed. It gives me more sound from the subs especially since I fire them toward the rear seat. The glare is a little irritating at night.
Old Oct 11, 2003 | 10:22 PM
AcuraX2's Avatar
I tried it both ways and found no difference back when I had my Kicker 10L7. I even pointed the sub straight up thru the hole and found no difference at all.
Old Oct 12, 2003 | 09:48 AM
shawhite's Avatar
personally i think the difference will be mental.. kind of like adding a cai to your car... it sounds cool so you think you car is faster but in actuality on the dyno there is no real hp gain.. same thing will apply here.. if you believe you are gonna hear a difference then you will but i will lay dollars to donuts that if you had the proper test equipment and checked it out you would see very little if any actual gain... just my opinion of course..
Old Oct 12, 2003 | 10:34 AM
bozzchem's Avatar
Sounds like it's not worth the trouble. Thanks for all of your responses!
You'll have to check my page when you get a chance. I just installed the JBL 608GTi comps. Once again I just had to go drilling and cutting. I didn't want to mount the tweeter in the sail panel so I made a hole in the door panel for it.
I don't know if it's the sound deadening material or what but these comps are definitely superior to the ID Chameleons! The tweeter is a bit on the bright side but since I'm used to listening to Klipsch speakers in my house I've gotten used to the brighter highs.
Old Oct 13, 2003 | 07:51 PM
B-Diddy's Avatar
9th Gear
I removed the Blose (i mean Bose) sub and it made quite a bit of difference for my setup - 2 12" JL Audio W3V2 in a sealed box firing backwards towards trunk. With the Bose sub in, it sounded like my bass was muffled and not very deep. I also found that moving the box forward a bit instead of having it all the way back against the rear seat made a big difference for some reason. Lowering the armrest helped slightly, but I would say the difference was barely noticeable.
Old Oct 14, 2003 | 03:55 PM
root's Avatar
I noticed a huge difference with the sub out. Definately do it. There is no need for it to be there anyways
Old Oct 15, 2003 | 02:54 PM
AceTL's Avatar
You can also remove the ski pass-through door itself if the glare from the light bothers you.
Old Oct 15, 2003 | 03:52 PM
fastcarz3's Avatar
i had the sub both in and out i didn't hear a difference but i do hear a big difference when you lower the ski pass
Old Oct 16, 2003 | 12:17 AM
the only time it will make a difference is at low volume, but once u turn it up,it sounds the same.
Feb 25, 2020 09:57 AM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
handsom-hustla
Nov 13, 2015 05:04 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
