TL: Remote Start Help
Old Dec 4, 2011 | 03:31 PM
stavebomb's Avatar
Remote Start Help
Winter is almost here in full swing, and I would like to get a remote start set up. I just want the most basic set up. I don't need an alarm. I simply want to turn the car on from inside my house, so that it can warm up before I go out to it in the thick of the winter. Does anybody have any recommendations for a cheap basic system that works? DIY instal diagrams? I have a 6MT.
Old Dec 5, 2011 | 02:25 PM
stavebomb's Avatar
Bump.
Old Dec 5, 2011 | 05:31 PM
BoricuaTL's Avatar
05 WDP 6MT
i install viper products. the common unit we have here is the viper 4103 or viper 5101. both technically the same, but the remotes look different. no matter which unit you install urself or have someone install, you will need a bypass because of the immobilizer system in our car. these remote start units installed with parts range about $350-400. if your just getting the equipment and DIY, your spending about $150-200. dont go too cheap and get lower quality equipment. your will not be too happy when it doesnt work all the time good luck
Old Dec 6, 2011 | 09:25 AM
KaMLuNg's Avatar
stave... are you looking to have it integrated (i.e... using your OEM remote instead of having another pager) if so there are some units that will tie into the OEM alarm and just provide an autostart feature... downside is that the range sucks... and not sure if they have made it work for the MT yet...
if you would like full coverage, i would agree with boricua as to go with a quiality DEI product... (Viper, Python, Clifford, you can't go wrong)
Old Dec 9, 2011 | 07:40 AM
stavebomb's Avatar
Thanks for the replies. Do you guys have wiring diagrams so I can do this myself? When I was at Best Buy looking at these things, they told me that viper requires a $49.99 a year service fee. Does this seem right? If I did it myself, would I still be subject to this fee?
Old Dec 10, 2011 | 01:33 PM
supra88's Avatar
simple inexpensive easy to install and best unit for the price will be the DEI 561T is from viper and can be wire to use your factory key-less entry remote the only problem will be the range it will start the vehicle by locking the doors twice or 3 times
or you can get the same version remote start with remotes for under $80.00 dei valet 561r
i have the wiring schematics
Old Dec 19, 2011 | 12:06 PM
parts guy's Avatar
7th Gear
Has anyone ever tried to bypass the immobilizer by attaching a spare key to the column inside the shroud near the ignition switch? I have a broken key and have tried mocking this up and it seems to work if you're looking to save some money.
Old Dec 31, 2011 | 03:03 PM
blaine209's Avatar
Just get a bypass that does jot require key
Old Jan 17, 2012 | 11:02 PM
frodosphotos's Avatar
I have the Viper 5301 that I picked up from my buddy. I just don't know if I want to find a way to install it myself or take it somewhere...
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
