Recommendation on exact fit speakers
Old Apr 10, 2004 | 12:47 AM
NICEUP's Avatar
Can anyone give me speaker brands that will fit my 99tl without mods. with good quality.
Old Apr 11, 2004 | 01:36 PM
TLSAnthracite's Avatar
is it the same as the 03? cuz i want to know too...
Old Apr 11, 2004 | 01:53 PM
shawhite's Avatar
i would say almost any 5 1/4 will fit with no problem.. you may need to make a spacer ring but it would not require cutting... as for 6 1/2 maybe the infinity 6002si (slim series i think that is the right model number..).. polk db's... but if you are looking for components that fit then maybe the focal poly k slim series...
Old Apr 12, 2004 | 11:47 AM
riontegra's Avatar
Smile
I've been searching for this exact answer for some time. I forget who the person was, but he wrote an extensive thread on exact speaker size, mounting depth, etc.
After very extensive research, I found the perfect speaker. They are the 6.5" POLK DB650. They can be found at most high end stereo shops and also circuit city. http://www.crutchfield.com/S-t1qDgUp...asp?I=107DB650
I just completed the install last week and I did not have to cut or modify ANYTHING! Even the stock factory mounting basket remains completely stock! These are truly a direct drop in plug and play. The only thing you will need a wiring harness adaptor if you don't want to cut the factory harness and some longer mounting screws. I have heard the Infinity 6002i will work as well, but I have not tried them and cannot say for certain they are truly plug and play. I chose the POLKs because they had better bass response.
I wanted a speaker with a high sensitivity rating so as not to lose too much volume and found these POLKs where rated at 92dB. I am very pleased with the outcome, however the high notes will be a bit bright due to the factory equalizer over compensating for the crappy stock speakers. The bass response is much improved, as is the general sound quality. It no longer sounds like an clock radio!
Old Apr 12, 2004 | 01:36 PM
NICEUP's Avatar
Speaker Size
So if understand correctly. Let's say if I wanted components in the front and reg. speakers in the back, for best fit and quality I can use 6.5" POLK DB650 in the back and use shawite focal components in the front? Would that work and shawite, What is the model for the focals because I can't find the one you are talking about?
Old Apr 12, 2004 | 04:32 PM
shawhite's Avatar
my bad it is the polyglass that has the slim series... the model number is the 165 V slim... but you are more than likely still going to need a spacer...
Old Apr 12, 2004 | 04:35 PM
fsttyms1's Avatar
im looking at these, are they any good? http://www.polkaudio.com/car/product.php?name=db6500
Old Apr 12, 2004 | 08:23 PM
Rusky's Avatar
My baby's daddy
im looking at these (DB6500), are they any good?
Yes! I just finished my install and they are excellent. I do recommend an amp, however. I put DB6500's all the way around. In the front, I mounted the tweeters on the triangle in front of the window. For the rears, I mounted them to the front of the stock speaker basket, behind the door panel, and cut a hole to let the sound through. You can't tell I changed the speakers at all. The mid-bass fit perfectly in the stock speaker basket with no modification other than drilling a hole to feed the cross-over wires through.
Bottom line, you don't have to cut any metal and the install is about as easy as components can get. ...and they can handle a lot of power should you throw it at them.
Old Apr 12, 2004 | 08:28 PM
fsttyms1's Avatar
you mind me asking where and how much you got them for? i cant find them in any store around here.
oh and did you use the 6 1/2 in the front too?
Old Apr 12, 2004 | 08:42 PM
Rusky's Avatar
My baby's daddy
Polk db6500 at crutchfield
First, here is my post fresh after the install
http://www.acura-tl.com/forums/showp...3&postcount=18
second, to answer your question, I got the polks from crutchfield. They still have a special on Polk. Buy one pair, get the second half off. That's why I went components all the way around. The back doors install so easy that I am really gald I did. It sounds so much better already and I haven't yet installed the amps.
My referral code (all crutchfield customers get one) is pth03-ss894-5piq7. You will get an additional $20 off (and I get $20 off my next purchase).
So total is (199 + (199/2) -20) $280 for all four. You can get the db650 in the rear and save $50. (free ship)
yes, components front and rear
Now, as for amplfiers, shop around. Deals everywhere but don't last long. SoundDomain.com was the best. For wires (interconnects), use Buy.com.
InfiniteCarAudio.com had some great stuff and awesome prices.
Everything is here except I am still waiting on my sub ;>( backordered...
The metra kit is at HiFi buys. sand the face to match color better.
THere you be
Old Apr 12, 2004 | 09:58 PM
fsttyms1's Avatar
THere you be
thanks for the speaker info! that is a deal. im gonna put a little money together here and do that.
oh and the sand the metra kit thing that was me who did that originally
Old Apr 13, 2004 | 08:10 PM
NICEUP's Avatar
Diy For Speakers Install
THere you be
This might be asking alot, but I am going to order the db6500 front & db650 rear from c.field. I need to know what tools I need for a diy for a 99tl. What tools i need, how do i do it and the process for the installation. Also if you know any diy that i can look at.
Old Apr 13, 2004 | 09:00 PM
NICEUP's Avatar
Speaker Size
I checked them out. They fit the front but not the back.
What you think about the MMC650?
http://www.polkaudio.com/car/toolbox...&trim=Standard
Old Apr 13, 2004 | 09:48 PM
fsttyms1's Avatar
correct me if im wrong but if they fit the front they should fit the rear?
Old Apr 13, 2004 | 10:15 PM
NICEUP's Avatar
I think you are wrong. I am no audio tech freak, but from what I have heard from audio experts the rear are more difficult to install and the mounting depts are smaller. I even called crutchfield and they said the same thing. Don't get me wrong the db650/6500 will fit the rear but they are no drop ins, yuh know. Yuh must do some alterations. I want to upgrade from stock, but do not want to f-up my car and mess up the resale value.
Old Apr 14, 2004 | 09:01 AM
fsttyms1's Avatar
ah thats where we differ. i wasnt looking for an exact drop in. i just want good sound. if i have to make a spacer, or do a little cutting thats ok with me
Old Apr 15, 2004 | 12:10 AM
NICEUP's Avatar
Well I think that I might get the db6500 all around, if you interested I found a better buy than at crutchfield, check out the link below $125 a pair
http://store.thestereohouse.com/db6500-.html
The only thing I do not know if to buy them and put them down, because I am not ready yet to install them. I am still doing research on a complete stereo diy.
I need to know the diy's , parts (eg.harnesses, wiring) and tools needed for>>>>
db6500 components all around
800 watt 4 channel amp
2 12 inch subs sealed box
600 watt 2 channel amp
still needed >>>
solutions for i-pod(or equiv) install
Blitzsafe adapter
pd4 adapter
HELP ON INSTALL NEEDED NY AREA
Old Apr 15, 2004 | 12:38 AM
NICEUP's Avatar
Check out the links below for the adapters I intend to use for an i-pod install and amp install while retaining the stock hu and navi voice.
http://www.linkmeup.com/
http://www.blitzsafe.com/blitz_catal...ra_alpine.html
If anyone can help me out on this install let me know what else i need to getand what else i need to do.
Old Apr 15, 2004 | 12:48 AM
ou sig's Avatar
Boomer SOONER
"resale value" seriously, all you have to do is a little cutting, no big deal, not going to hurt anything - only help.
Old Apr 15, 2004 | 12:56 AM
RecklessTL's Avatar
Rusky do you have pics of the install ??? I already have an alpine 5 channel amp laying around and i am wonder if the install would make a great difference , i plan to be putting in a 10w7 in the near future 2 thanx reckless
Old Apr 17, 2004 | 09:28 AM
NICEUP's Avatar
I am planning to something similiar to yours except the the hu, I am keeping mine. Do you have notes of your diy?
Old Apr 17, 2004 | 01:44 PM
sorry for repating, then what is the perfect fit for the front and the back??
db6500 in the front and what in the back??? I'm talkin about plug and play, thanks
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
Pegon95
Sep 15, 2015 01:54 PM
Joe Tschida
Sep 13, 2015 12:22 AM
