Rattles....!
Rattles....!
Rattles Everywhere...! I recently installed a amp and sub and wow I got rattles everywhere.. I do have some Dynamat.. Can someone tell me what the most common rattles are? I think the worst I hear is from the top trunk by the spoiler... Thanks..
Not Asian
When I first installed my amp and sub, the rear shelf rattle like crazy. I just fixed it this past weekend and my cabin is quiet once again.
What I did was remove the shelf, which requires to remove the backseats. I then applied rubber foam weather stripping, that you can get from Home Depot or Lowe's, around the edge underneath the shelf. I also put some around the brake light that touches the window.
I also found the main culprit of the rattle was the two hard styrofoam cubes under the shelf hitting the metal parcel shelf. Just put some of the weather stripping under that as well. Now the shelf sits back there very snug. I'm very happy with it, considering it only cost me about $3 for the weather stripping.
Not Asian
Originally posted by Hobo
i filled the holes in the trunk lid with spray foam... helped a lot
Originally posted by phipark
Did you just use Great Stuff or something like it? Do you think this would be equivalent to Dynamating the trunk lid?
THE SILVER BULLET
my car sounds horrible and i dont know what to do i just dynmatted the trunk and it rattles a shit load still the inside,rear deck, rear bumper, trunk everything!!!
Flap.
i used great stuff... it worked wonders.. i also have a sheet of dynamat xtreme on the trunk lid
Not Asian
Originally posted by pimpscls
how do you take of the bolt for the seats, that angle is impossible for me to do, is there a trick for it
Nosfera2
06-10-2008 06:48 AM
