radio removal question
MAC USERS RULE
what are the steps to removing the Factory Head Unit? I have to install a Parrot ck3100 Bluetooth kit and I need to remove the Headunit to do this.
Thank you,
Jason.
Thank you,
Jason.
Rep'n Taxbrain.com
First off, this is going completely off the top of my head. Hopefully I don't miss any steps. I haven't done this install for like 6 or 7 months. I would try to look for the install instructions for the wired OEM cell phone interface. They cover removal of the stock radio in order to access the mute pin.
*First tape everything up with blue painters tape.
1) Remove the storage bin
2) Remove the silver trim on the left side of the factory HU and on the right side of the HU above the glove compartment. You might need some type of hook to not damage it. Be careful with it.
3) Remove the Hazard light harness and disconnect the harness for it. Remove the bolt behind the harness.
4) Reach in the storage compartment area and feel up. You should be able to feel two bolts there. You'll need a small socket to get those out. Remove both of those.
5) You should be able to slide the factory HU out now. It's held on in some area by clips. So just pull it out.
Hopefully I didn't miss anything. Good luck.
Luis J. Rodriguez
09-12-2015 10:00 PM
