Quick + and - speaker wire question
Old Sep 12, 2007 | 11:30 PM
wong05tsx's Avatar
Need more room in
how do you indentify the postive and negative on a speaker wire - I got my system professionally installed today and I decided to move one of my amps to mount on my back seat, but when I disconnected everything I forgot to mark which speaker wire is + and which is -.
How can I check? Is it safe to just hook it up and listen to it (i figure if its backwards, no sound would come out)?
I can't do the AA battery method because the speakers are behind doors so I can't exactly watch the cone move
Installer also isn't answering his email and I'd like to fix this tonight, thanks
Old Sep 13, 2007 | 12:28 AM
zidenx's Avatar
i think either way you hook it up there will still be sound.
Old Sep 13, 2007 | 12:38 AM
wong05tsx's Avatar
Need more room in
i did a search and it said if its wired backwards, it'll be out of phase and could hurt the speakers, but I can't exactly tell since I can't see the speakers itself!
Old Sep 13, 2007 | 01:02 AM
G22_Powered_YA1's Avatar
the sound will end up messed up but theres no real damage to the speaker, people run their subs at reverse phase all the time, its just moving the opposite way than usual (pulling when it should be pushing).... it might hurt the tweeters, but i think its safe..... either way, try one, listen, and try the other and listen to that, pick the one that sounds better and proper to you
Old Sep 13, 2007 | 01:09 AM
wong05tsx's Avatar
Need more room in
^thanks
will try this when theres light again outside, pitch darn now =(
Old Sep 13, 2007 | 11:12 AM
Reach's Avatar
Look at the wires. Your + wire will have a mark on it that the - wire doesn't. Thats usually the convention.
Old Sep 13, 2007 | 03:06 PM
Weavz's Avatar
Wires
Usually it's really hard to see it too....look for white text running the length.
Old Sep 13, 2007 | 03:38 PM
phipark's Avatar
Not Asian
The positive usually has some writing on it.
Old Sep 13, 2007 | 10:35 PM
wong05tsx's Avatar
Need more room in
figured it out, digged around looking for where he mounted the the crossovers and got the hint off that.
Paid 250 for 4 doors + metal cutting + spacers + speaker wires + 6hrs of labor and I told em I'd do the trunk myself to cut off an hour of $$$ . Took me an hr 1/2. 1/2 hour trying to mount MDF to the back seats, but couldn't get it to work so i jst said screw it and mounted it to the box. here's the results
note: shorter RCA shipping to me, gonna hook that up before i tie up all the wires back there - can't see them anyways when the seat is up.
and a little finishing touch
Old Sep 13, 2007 | 10:54 PM
zidenx's Avatar
what's your setup?? looks similar to what i'm getting for mine.
nevermind, just looked you up and found what you're running. how do you like it so far? how is that sub?
Old Sep 13, 2007 | 11:18 PM
wong05tsx's Avatar
Need more room in
the sub is a great bang for the buck, I actually have a brand new one laying here in my room never opened with 7 months of warranty left on it, I was gonna hook that up too but can't exactly afford a bigger amp + box + bigger power wires etc.
At first I had this sub hooked up to a alpine mrd-m605 & thru LOC of the back 6x9's on stock speakers and it sounded pretty good. but aftermarket speakers and amp makes a huge difference. Only reason i switched to JL amps is cuz of the balanced diff. output shit thats required for mercmans harness (great harness btw). If you're going to add a sub in the trunk i'd suggest disconnecting the rear 6x9's and removing them, adds some more venting into the cabin and you feel more bass
Old Sep 13, 2007 | 11:24 PM
zidenx's Avatar
yeah, i'm going to be running my system exactly the way you have it.
rainbow cmx 256 kicks up front
dunno what i'm going to replace the rear doors with yet
jl audio 10w6v2 sub
jl 500/1
jl 300/4
Old Sep 14, 2007 | 08:55 PM
wong05tsx's Avatar
Need more room in
think i blew my subs today =(. they were workin fine before i went to school, as i was leaving i noticed it wasn't slappin as loud, then 5 minutes into the drive i started to smell something so i was just thinking it was the box since i havnt used it ina few weeks. I get home, open my trunk, and theres smoke coming out of my box.
the sub still works but it sounds like sh*t and makes some weird noises. blown voicecoils? blown sub? does warranty cover this?
this is an alpine type R
Old Sep 15, 2007 | 11:33 PM
Reach's Avatar
yikes. I have no idea, and not sure I could without being there to examine it. You better have that shop you took it to for the work go over it.
Old Sep 16, 2007 | 04:52 AM
wong05tsx's Avatar
Need more room in
too lazy to go back to the shop + gas ;x. Just gonna send it to alpine for warranty which would prolly what they would tell me to do anyway.
Meanwhile, I popped the brand new type r thats been sitting in my room for the past 4 months in the trunk, and it seems alot louder than the one that just pooped on me, and i havnt even touched the settings. No problems yet
Old Sep 16, 2007 | 03:14 PM
zidenx's Avatar
Well it's better to make sure everything was wired correctly or tuned right so this sub doesn't blow out also.
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
