question on power wire for system..
Old Aug 1, 2001 | 02:20 PM
wiggingboy's Avatar
i'm going to hook up a system in my car soon. i was wondering where there is a hole so i can run the power wire thru, from my engine to the inside and how many gauge wire should i use?
thanks
Old Aug 1, 2001 | 02:53 PM
Wampum's Avatar
Power Wire
I do not know about the 2nd Gen TL's. All I did was run mine through an existing grommet(sp?) There are plenty of web pages that will give you a rule of thumb of what guage wire to run and at what length. How much power are you planning to run? What size amps? What kind if current do those amps draw?
Old Aug 1, 2001 | 10:46 PM
jdl75's Avatar
Re: question on power wire for system..
thanks
What is the size of the amp(s)? My RF punch 400.4 will only take up to an 8AWG power cable. Bigger 'n 400 wats, or multiple amps, you could consider a 4AWG cable. Honestly, from an enginering standpoint, it is a waste to go bigger than 8AWG for the power. There just isn't that much power in the battery.
As for the hole in the fire wall, look under the driver side dash, to the upper left of the brake pedal. Poke a pen or something through the hole (nothing sharp or that will break), and look for it under the hood. There is your pass-through.
Install Doctor has some very good info. Nothing specific to the TL, but they are not that much different than other Hondas in these respects (although Bose probably uses different wiring harness schemes).
There are also a few good install kits available. I just did my 2001 Accord, and the Rockford Fosgate power kit made it a breeze.
Old Aug 1, 2001 | 11:38 PM
Smile Also trying a Search usually gets good results.
Read my post here. Also you should run at least a 4 guage power wire. That should hold you for a while.
Pics of my system coming this weekend
Old Aug 1, 2001 | 11:52 PM
wiggingboy's Avatar
Thanks alot for the reply guys...
i know its gonna help me out alot.
Old Aug 2, 2001 | 03:36 PM
jdl75's Avatar
Re: Also trying a Search usually gets good results.
How many amps did you run, and at what power? What made you decide to go with 4 gauge wire? I'm just curious - all of the equations say it doesn't matter, but I've been around long enough to know experience counts for something :-)
I look forward to your pics!
Old Aug 3, 2001 | 01:46 AM
wiggingboy's Avatar
I'll be running about 1200 watts. 800 for the subs and 400 for the mids and highs. and the amps i'll be using is AUDIO ART, duno if you guys every heard it but it pretty good. i like it.
Old Aug 3, 2001 | 03:08 AM
Wampum's Avatar
What kind of current do those amps draw?
Old Aug 3, 2001 | 05:33 AM
mr tl's Avatar
run 4 guage for your setup
8 should be the minimum. if your using something thinner than 8 guage, its probably not even worth upgrading a system
Old Aug 3, 2001 | 12:10 PM
wiggingboy's Avatar
Ok thanks alot guys..
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
