Question about tapping remote wire
Old Feb 25, 2002 | 03:07 PM
TypeSKid's Avatar
Ok. the wire you tap into off the stock amp is yellow/white correct? Tried that, and I still don't have any power to my amp! Everything else has been done, I can't figure it out.
Any suggestions?
Old Feb 25, 2002 | 03:34 PM
JasonT's Avatar
Bad ground?
Old Feb 25, 2002 | 04:26 PM
TypeSKid's Avatar
Would a bad ground cause it to not be working:+?
What should it be grounded to:?
Old Feb 25, 2002 | 04:44 PM
icy CL's Avatar
there are two wires that are white/yellow. make sure you tapped into the wire that has dominant yellow with a white stripe. the other one is more white with a yellow stripe.
http://silverknight.clickhere2.net/sound.html
Old Feb 25, 2002 | 06:18 PM
TypeSKid's Avatar
IF I can't get any power to the amp from this, then what do you think it could be?
Old Feb 25, 2002 | 09:25 PM
icy CL's Avatar
fuse, maybe?
Old Feb 25, 2002 | 09:45 PM
SilverKnight's Avatar
Retired. Not available.
There are 3 power connections on an amp.
BATT: connect to battery.
REMOTE: connect to a wire that is turned on when the head unit is on (can be connect to ignition wire which is on when your car is running).
GND: connect to the body of your car via a short route available.
If you have made all three connections and your amp doesn't turn on, check the following.
1. Fuse
2. Make sure your remote wire and power wire are "hot" (the voltage should be at least 12v).
3. Ground cable is connected securely to the body of the car.
If all of these conditions are met, kiss your amp good bye.
Good luck.
Old Feb 25, 2002 | 11:16 PM
lowpost's Avatar
1. Fuse
Good luck.
it'll probably help you to buy a test light also - they're cheap and can tell you what wire is live
Silver - what's your opinion, is it better to ground to the chassis or back to the battery?
Old Feb 26, 2002 | 09:36 AM
Chassis only, please. I'm at work so this is all I could type but I can guarantee you no one would recommend to tie ground to the battery terminal.
Old Feb 26, 2002 | 11:21 PM
lowpost's Avatar
I've heard opinions either way. My first two systems were grounded back to the battery and I never had any problems, even with the Soundstream Class A amps which are notorious for noise if not grounded properly. Some installers I've talked to told me that most installers ground the amps to the chassis only because it is easier/convenient and it's just more of a pain to run a 4 guage ground from the battery to the trunk. But give a choice, they would groun to the battery becasue it was cleaner, circuit-wise. Now none of my systems were load heavy/competition systems so I don't know if that makes a difference.
Is there a specific reason why you don't recommend grounding to the battery?
Old Feb 27, 2002 | 03:33 PM
I have to agree with what you said.
1. Convenience.
2. The ground cable comes from the battery terminal may pick up noises from the alternator or noises from other wires (unless you use high quality wire and route it away from vehicle's wires).
Old Feb 28, 2002 | 10:46 PM
lowpost's Avatar
1. Convenience.
yeah, ultimately you're more right 'cause the chances of getting engine noise from grounding to the battery is a lot higher. If you did that and ended up with noise, that would be a big waste of effort.....but if you make it out ok, then a good ground is a good ground no matter where it goes to.
Feb 25, 2020 09:57 AM
deyainrdy4ds
Sep 22, 2015 10:15 AM
Sep 17, 2015 09:01 PM
datadr
Sep 12, 2015 09:12 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
