Question about Line Out converter
If I have a 2 channel line out converter, how do I hook it up to the factory 9" sub in order to get the signal to my aftermarket amp and sub??? Also, How can I run 2 amps, i.e. one for each of my 2 JL 10"s???
Y2K Satin Silver/Ebony 3.2TL
AEM SRI w/ custom CAI conversion | Magnaflow axle-back quad exhaust w/ modded downpipe | Neuspeed Sport springs(modded: 3.5"F/3"R drop) | Acura OEM Wing | Mesh grill | "Euro" Headlight finishers | Graphics by GBM | Acura Indiglo Emblem | Mugen badging | Body color door handles | Polarg M-12's/Eurolite Hyper Blue's | Opti-Blue Xenon High beams | Hiper Strobes | 20%/35% Llumar tint | Razo RA42 Shiftknob | Alloy pedals | Dual 10" Blue neons in bumper | 200 watt Audiovox bass tube | Escort Passport 7500
Just get a Y-adapter. Why do you want to run 2 separate amps anyway?
You can hook up the converter from the wires going directly into the sub, you do not even need a crossover, the signal going to the factory sub is already crossed over for low frequencies only.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
My AcuraTL Homepage
Hang on hang on....back up here a second.... the wires going DIRECTLY into the sub???? Not a good idea, eventually you will blow out the line converter or the amp, or both from the signal that is output by that factory sub amp....
I know a couple people that did exactly that and toasted some shiznit.
I did it and fried my converter and subwoofer. If you hook up and amp use the wires before the Factory amp.
00, TL, Blue/Pearl
Eibach springs, Piaa platnim fogs, sidemarkes, CL-S wheels w/215-45-17 rubber, MTX Amp and Subwoofer, custom white "A".
"STILL UNDER CONSTRUCTION"
00, TL, Blue/Pearl
I hooked it up from the wires before the amp first, the signal was so low that I had to turn the gain up all the way on the line out converter AND the amp and I could hardly hear anything.
Then I tried to hook it up from the signal going directly to the sub, it go better signal, I still have to turn the gains on the line out converter all the way up and the amp gain 1/8.
Also, My 2 channel Line Out Converter has 4 wires coming out of it. They are R+ and R- and L+ and L-. How would I wire it to the signal? Just use one set either Left or Right, correct? And what are the BOSE wire color codes?
i dont remember which one is positive or negitive but just connect 1 to the outside (-) and the other to the tip (+) or use an old cheap rca and cut it strip the ends and try it. it should work either way because both your amp and the stock head unit are floating ground. but if you get it backwards the sub will be 180 out of phase. worked great for me i dont know what the output is exactlybut it was able to push the aftermarket amp and sub pretty easy with gain up 1/2 way
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
How did u interface the RCA plugs into the factory preamp wires???
AEM SRI w/ custom CAI conversion | Magnaflow axle-back quad exhaust w/ modded downpipe | Neuspeed Sport springs(modded: 3.5"F/3"R drop) | Acura OEM Wing | Mesh grill | "Euro" Headlight finishers | Graphics by GBM | Acura Indiglo Emblem | Mugen badging | Body color door handles | Polarg M-12's/Eurolite Hyper Blue's | Opti-Blue Xenon High beams | Hiper Strobes | 20%/35% Llumar tint | Razo RA42 Shiftknob | Alloy pedals | Dual 10" Blue neons in bumper | 2 JL10W subs | Boss CLR60 600 watt 4 ch. amp | Escort Passport 7500
Hey,
I have the same problem I think. My 600 Watt amp, and 2 10' subs were working fine. Then all of a sudden my amp stoped working. I had an indiglo emblem hooked up to the ground from the amp. Do you think i need a new amp?
IIDXholic
10-08-2015 07:53 AM
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
Skirmich
09-15-2015 06:41 PM
alan_rich
09-07-2015 11:08 PM
