Problem with USA Spec Adapter in 2004 TSX (non-nav)
Old Dec 11, 2007 | 06:40 PM
jdanto3's Avatar
8th Gear
The adapter has worked perfect for almost a year now, but this past week I've started have trouble. When I switch to the auxillary channel, the adapter attempts to switch to the Ipod then turns off again. The radio display initially goes to the "CD-C 5", but then switches over to "CD-C 6" after the adapter fails. You could be choosing a song on the Ipod and when the adapter decides to turn off, it will send the Ipod into the charge mode wth a black screen. I tried it with my other Ipod video and have the same problem.
I searched the forums and could not find any similar issues. Has anyone heard of this before or have any suggestions? I appreciate any and all help.
Old Dec 11, 2007 | 10:48 PM
Reach's Avatar
The 1 time I had trouble with it not initiating correctly (something like this, but not quite) it ended up being a loose connection at the ipod cable -> usa spec connector. I'd just remove the adapter, re-install it and make sure all the cables are well seated. I taped the ipod cable into the socket pretty well, and it never came loose again and never game me another minute of trouble.
Old Dec 13, 2007 | 12:17 AM
jdanto3's Avatar
8th Gear
Thank you for the help. I'm going to give it a try tomorrow after work.
Old Jan 1, 2008 | 03:40 PM
jdanto3's Avatar
8th Gear
Problem Fixed
USA Spec sent me a replacement for the cable that goes between the Ipod and the aux unit. Solved the problem and works perfect again.
jriv7
May 8, 2020 05:50 PM
cycdaniel
Dec 17, 2019 10:58 AM
EvilVirus
Dec 10, 2015 07:38 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
nuldabz
Sep 3, 2015 05:49 PM
