Problem with Clarion
9.5 lbs o' Boost!!!!
I just installed a clarion in dash screen in my car and I have a few problems with it that I am hoping i can resolve ASAP.
1. I tried putting in a DVD. the instructions say to simply put in the DVD and it will play however I only heard the movie and the diplay said "audio only" WTF!!
2. I have a annoying fuzz that is only audible when the volume is one 1. the fuzz or interference does not get louder as the volume does however it is distinctive and annoying. The fuzz is there when I play my I pod, CD, and Radio.
I have no clue what to do and would appreciate any suggestions.
Thank you.
Thank you.
Former Sponsor
Thank you.
Thank you.
Word?
Which is the correct bose interface module? is that something i have to buy seperate? I know the parking brake wire is green but dont know where it goes...... Thanks for the help.
Former Sponsor
The correct module to add an aftermarket deck to your factory BOSE system is the PAC OEM-2. There are several other brand models out there but the OEM-2 is bulletproof and easy to install. You can purchase one at most car audio shops or online.
get a regular switch from like radio shack. Wire the green wire to one prong and ground wire to the other prong on the switch. Then ground the other end of the ground wire to the chasis. Flip the switch twice and u can watch video whenever u want. Will post a drawing when i can find it.
id rather just set the parking brake wire the parking brake wire to a 12 volt source, then i can watch it anytime and wont have to buy a switch.
Like unclad said its not a 12volt signal its a ground. ANd you can't wire the green wire directly to ground, it won't work. It has to be on a switch, i know i've had to do it with my clarion max675 that i got last year.
Simple 3 dollar switch, small and can mount it anywhere out of the way.
ok cool. Now about that OEM PAC 2. FYI I dont have a aftermarket AMP. I only have stock. ALso where is the stock amp located? And finally, is the PAC 2 going to eliminate the fuzz sound..... I appreciate your help.
Originally Posted by uncald4
Not a 12volt +. A Ground.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
