Probably been asked be4 but Please HELP
I have 2 JL 12W3 and a rockford bd1000 amp for those. I have Pioneer 6 1/2 (pair) and 6x9 (pair) powered by a 400 watt amp for the speakers inside. In addition I have a 3 way crossover. I don't want to change the head unit. Is there anything special I need to do. I've heard of adding an adapter but is there anything else. Can I keep the factory tweeters or should I change my front speakers to a component system.
the bose speakers have a different ohm rating than aftermarket amps and speakers. so, if you are going to use an aftermarket amp, i would suggest changing the tweeters too. i don't remember anymore how the stock tweeters sound since it's been a while since i've had them but i changed all the speakers, front and rear and i think it sounds much better, crisper highs, clearer mids and, with a sub, more powerful base (when needed). since you already have the 6 1/2 speakers, just purchase a set of pioneer tweeters and you should be good to go. if you have more funds available, go ahead and get new component speakers for the fronts. i really think it did make a diff!! hope that helps!
Upgrade your front speakers to components is highly recommended. Since you didnt say what kind of front speakers, I assume they are coaxial. This means there are tweeters built-in already. If you just replace the stock with these. Then you are running 4 tweeters. That will screw up everything for good. You have high frequencies travel from different paths that arrive your ears at different time
. I would leave the stock components (but with an aftermarket amp to power them, I just get a cheap components) untill I'm ready to upgrade to a decent set. Good luck.
I went to the place where I'm going to get my system installed and I asked them about components for the front. They told be JL Audio would be the best component set to get. If I do get the JL components for the front and keep my Pioneer 6x9's will it sound different or messed up? I'm just not sure of having 2 different brands for front and rear speakers.
Well this is what I'm 90% sure of what I'm going to do. Since the speakers I have from my Legend (6 1/2 & 6x9) are both 3-way. I think I'll save my time and money and use the 6 1/2 I have since they are 3-way and just disconnect the tweeter. Damn why didnt I think of that earlier. Thanks for all the help peoples. I'm gettin it installed probably next week.
