powering car
powering car
I am not sure which thread to put this in so here it is. I have searched the web for countless times looking for a device I do not know the name of. I am looking for the device that people use when they show there cars indoors and have the car hooked up so that they do not drain there battery and have full power all day long. Hopefully someone here can help me out with what it is called and maybe even tell in what range I am going to have to expect to spend.
Originally Posted by Xtremespeed2102
how big should it be? some of these look a bit weak for the car, yet the battery itself is small....
Since most AC-DC converters are rated in amps, just add up the drain from everything you're running in watts and divide by 12 to get amps.
So if you're going to run a 500w stereo with 5 interior 10w lightbulbs you're going to be drawing about 46 amps:
500w stereo
5x10w bulbs
=550w
divided by 12volts
=45.8 amps
so since i am running a 500W sup, a playstation 2, a laptop, 1 possible 3 video screen, my interior and underbody lights and posiible some other lights i am going to need a rather big one
so basically i need this http://www.analyticsystems.com/products/pws1501.htm
The favorite one used by factory demo cars is the Cascade Audio.
http://www.cascadeaudio.com/prod/powersupp.html
Since it's basically a big inverter, you need one to be as clean as possible or you could get audio and video noise. Also, most 12V components aren't designed to run with much noise on the input, and some devices run weird with cheap power supplies connected to them.
Astron is the company that builds big cheper supplies, but I am a big fan of the Cascade.
I have a decent cheaper 12V regulated supply for the bench, but I bought a Cascade for just that application. Haven't had to use it yet.
mike from annapolis
May 7, 2017 08:21 PM
