Possible to Install Blitzsafe w/o Dash Removal?
Old Jun 1, 2004 | 05:14 PM
whitehme's Avatar
I just picked up a Blitzsafe AUX adapter to plug my IPOD into the head unit. Can the cable be attached without some dash removal? If not, how much trouble is it to install, or should I wuss out and have a audio shop do it?
Old Jun 3, 2004 | 02:59 PM
shogun's Avatar
im the best
no it cannot be done withtout removing the center console. mainly to get to the side panels which is what i assume you mean by 'dash'? its not difficult at all, but that's a relative term. i'd recommend just doing it, saving money and understanding how it all goes together.
Old Jun 3, 2004 | 10:24 PM
DeathtoToasters's Avatar
I tried not to remove the actual head unit and stick my hands behind...it is way to tight for any hands!!
It took me an hour to figure that out.....and 10 in to ge tthe radio out. Go figure.
Old Jun 6, 2004 | 03:29 PM
HCHO2000's Avatar
http://www.abunchofcars.com/diy_page...er_console.htm
that is the step by step
Old Jun 8, 2004 | 01:50 PM
brader's Avatar
i have a 99 tl i removed the console and the side of it and the cd changer plug in that you need is on the right back side of the radio i just stuck the adapter in it was a tight fit but i have big hands so yes it is possible to do it without removing the radio
Old Jun 8, 2004 | 11:27 PM
StreetEffectz's Avatar
Yes, it is 100% DEFINITELY possible to do it without removing anything except the passenger side panel. It's a VERY tight squeeze and as long as you don't have huge hands, you should be able to maneuver it up in there....we do it all the time
Old Jun 9, 2004 | 03:31 PM
VTEC11's Avatar
Ron's right. It can be done. I did it when installing the CD changer cable. Was really really tight back there though, but can be done if you take your time.
Old Jun 20, 2004 | 09:49 PM
Bxscig's Avatar
Got any pics or pointers of how to remove the passenger side to get to the back to install?
Thanks.
Old Jun 20, 2004 | 10:28 PM
HCHO2000's Avatar
I have 2 pic's but dont know how to upload to Acura-tl.com e-mail me direct and i will sent them
HCHO2000@aol.com
tip 1. remove wood trim along raido see this site for help on that
Tip 2. unscrew the 2 screw's in under the carpet in the console once that is removed the side plastic will come of then the plug for the Blitz it right there Tight but there I have a good pic of that get me you e mail
Old Jun 21, 2004 | 05:46 AM
Bxscig's Avatar
Thanks, email sent. It looks like such a task to remove the center console. Would love to bypass all that work.
Old Jun 26, 2004 | 08:51 AM
I didn't remove the entire console. I just took off the right side panel next to the radio. I then bent the end of the adaptor back and taped it to itself in a "U" I was able to basically hook it into the inputin the back of the stereo and then pull it in until it snapped with one finger. This way I did not have to get my whole hand back there.
Old Aug 2, 2004 | 08:10 PM
ronrecr's Avatar
do you have the instructions as the web site is down
Old Aug 5, 2004 | 05:33 PM
rokji's Avatar
rokji
Can I install Blitzsafe on indash cd changer?
Because description says
This device is NOT compatible with any models that have the 6-disc in-dash CD changer or all 2003 or 2004 Accord.
Old Aug 10, 2004 | 08:02 PM
mikelee223's Avatar
Can the blitzsafe be install inconjuntion with trunk cd-changer?
Old Aug 11, 2004 | 04:02 PM
dun's Avatar
dun
no offense, i wouldnt wanna goto your store. but hey if it works for you
Old Aug 11, 2004 | 11:18 PM
Iggy's Avatar
Oh? Why is that? Have you been to Ron's shop or seen his work?
Old Aug 15, 2004 | 05:42 AM
JPritch's Avatar
All Hail the Chief
StreetEffectz does the best work I've ever seen on TL's, and would be my first choice for any A/V work I would have done to my car. I'd even drive up from VA.
So I don't know what your comment is based on.
Just in case you're curious:
www.streeteffectz.com
Old Aug 16, 2004 | 12:34 AM
dun's Avatar
dun
sorry i didnt mean to bash your company. Just the way u described 'your' installation by shoving the product in there. But i mean if i works and it still looks the same, i would def. do business with you.
Old Jan 6, 2005 | 07:56 PM
TLover8888's Avatar
which model Blitzsafe did you get?: the HON/ALP DMX V.1 or the HON/ALP DMX V.1D? what is the difference between the two?? anyone?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
ivegotthenav
Sep 11, 2015 07:51 PM
04tler
Sep 10, 2015 01:13 PM
