Possible to add a 5.1 Decoder to our system ?
Old Apr 22, 2001 | 03:07 PM
Post Possible to add a 5.1 Decoder to our system ?
Hi,
I just wanted to know if it is possible to add a 5.1 Decoder that I have to our car Bose System ??
Thank You,
Prashant Patel
2000, Acura TL, Black, Navi, Factory Wood Kit, Rear Spoiler,
Tinted, Viper Alaram & Auto Starter. Will try to put pics as soon as I can.
Old Apr 22, 2001 | 03:42 PM
miwa's Avatar
Post
Originally posted by goodbadmas:
Hi,
Thank You,
Prashant Patel
and then? you're gonna add a center speaker to make it worth the ordeal? I've heard of people tapping into the speaker level outputs with a line out converter to get yourself some line level inputs for the decoder. or maybe if your decoder takes speaker level inputs, then you can tap directly. I'd like to see how you set up that center speaker in your car to get your center channel.
Old Apr 22, 2001 | 03:55 PM
SteveStMS's Avatar
Post
Adding Dolby Digital / DTS to factory stereo can be difficult. What you need are the low level L&R outputs from your Bose factory head unit. Feed that into a Dolby Digital / DTS decoder, like Panasonics CY-AC300 as analog L&R input or Pioneer AVM-P9000R* or Clarion DVS9755z combo DVD player/w DD/DTS decoder. The 4 channel low level outputs then go back into your Bose amplifier, along with the new subwoofer and center channel output into a new amplifier.
* The Pioneer AVM-P9000R would work best with AVX-P7000 or AVX-P7000CD replacing your factory head unit. This unit also does not require to be connected back into your bose amplifier (all amps are built in). Think of this more like a complete stereo replacement.
Hope this helps. If your really considering a 5.1 setup, I'll help you further by describing the benifits and pro/cons of each of these units. I own all 3 of these models.
Steve
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by SteveStMS on April 22, 2001 @ ]</font>
Old Apr 22, 2001 | 05:02 PM
Post
Hi Steve,
Thanks for the info. But to be honest I m not going to do it myself ~ I will be coming to you directly to do it ! hehee ..
I have your phone number and I will call you sometimes tomorrow ~ I have a playstation 2 on my.
Also, there is a 5.1 decoder and a amplifier that came with the 5.1 system that I bought. I have the link where you can check and get back to me with more info if we can use it !
here is the link.
http://www.sherwoodusa.com/12volt/xdts_12fm.htm
you can use the left nav bar to navigate for more info.
Please check !!
Prashant Patel
Old Apr 22, 2001 | 07:38 PM
Post
Here is the link to the AMPLIFIER !
http://www.sherwoodusa.com/12volt/ax6275_12fm.htm
Prashant Patel
Old Apr 22, 2001 | 08:16 PM
Rice1304's Avatar
Post
anything is possible if you have the money.
Old Apr 22, 2001 | 10:16 PM
StreetEffectz's Avatar
Post
I'm actually going to do an install with this amp in a TL soon. It is MORE than possible, but like steve said, can be tricky.
Old Apr 22, 2001 | 10:19 PM
Post
Hi,
Opsss .. I didn't mean i Steve, I meant that i will go to RON to have it done !!!
Sorry for the confusion !
Prashant Patel
Tinted, Viper Alaram & Auto Starter. Pics here
http://members.tripod.com/goodbadmas/car/FrameSet.htm
Old Apr 23, 2001 | 01:08 AM
SteveStMS's Avatar
Post
That's good, because Ron is the one with 'the tricks'. It's always easier to give advise than do the work. I'll just recommend very complex installs and you can ask Ron to do it ;}
Steve
gatrhumpy
19
Dec 31, 2015 04:22 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
agupta3224
Sep 22, 2015 08:08 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
