posivtive....negative
Future Seminole
1 Post
.the 6x9's in the back which color is positive and which is negative?.......on one of them the 2 wires are pink and blue and the other speaker theyre red and orange
Future Seminole
1 Post
yea i did them correct then.....what i did was turn the 6x9 wires into rcas and run them to the amp. i have that pushing a type R 12. it doesnt sound right though mayb i just have to tune the amp? but it sounds like the sub is getting pushed way too hard and isnt making all that much bass. ne help?
You want me to break it?
The higher frequencies are filtered out by the stock amplifier - since your signal comes from the stock amp, there is nothing on this earth that will "correct" the low pass crossover point - to be able to play with the frequency range you would have to grab the headunit signal BEFORE it gets to the stock amp (ie behind the dash) - you are pretty much stuck with what the stock amp gives you by using a LOC (that is what you used, right?). Anyway, good luck.
