posivtive....negative
Old Mar 21, 2004 | 10:06 AM
acuratsx03's Avatar
Future Seminole
.the 6x9's in the back which color is positive and which is negative?.......on one of them the 2 wires are pink and blue and the other speaker theyre red and orange
Old Mar 21, 2004 | 10:56 AM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
Sort of on this same topic, does anyone know if the subs(6x9's) use a mono signal or is it two discrete channels coming from the amp???
Old Mar 21, 2004 | 12:04 PM
JTso's Avatar
acuratsx03, Left-rear speaker + is pink, - is blue/yellow. Right-rear spreaker + is red, - is brown.
Tireguy, not sure if the 6x9 rear speakers are using a mono signal or not. However, they both have different wiring connections at the amp.
Old Mar 21, 2004 | 12:15 PM
acuratsx03's Avatar
Future Seminole
yea i did them correct then.....what i did was turn the 6x9 wires into rcas and run them to the amp. i have that pushing a type R 12. it doesnt sound right though mayb i just have to tune the amp? but it sounds like the sub is getting pushed way too hard and isnt making all that much bass. ne help?
Old Mar 21, 2004 | 06:52 PM
ortiz's Avatar
Don't listen to me.
You need a high to low signal converter. Also remember that the 6x9 line have a built in high filter. So only low signals will pass through.
Old Mar 22, 2004 | 07:18 AM
acuratsx03's Avatar
Future Seminole
but dont i want only low signals passing through cuz its just a sub? will the converter correct this?
Old Mar 22, 2004 | 08:14 AM
Gpump's Avatar
You want me to break it?
The higher frequencies are filtered out by the stock amplifier - since your signal comes from the stock amp, there is nothing on this earth that will "correct" the low pass crossover point - to be able to play with the frequency range you would have to grab the headunit signal BEFORE it gets to the stock amp (ie behind the dash) - you are pretty much stuck with what the stock amp gives you by using a LOC (that is what you used, right?). Anyway, good luck.
Old Mar 22, 2004 | 09:56 AM
tuan209's Avatar
could get a new amp tho?
