Please help trunk rattles like crazy
Old Jul 4, 2001 | 03:29 AM
Mr.T's Avatar
Angry Please help trunk rattles like crazy
Please help me guys,
I'm so desperate. My trunk rattles really bad. I use extreme dynomate for the top trunk. I use 2 layers. I don't want to use the spray in my trunk cause than I can't get to the wirings I stuff the hollow areas of the trunk with the same material as the people use in the sound room to keep the sound inside. Please if anybody tride anything else let me know. I hate the ratttle in the trunk. It's so bad that the rattle is louder than the bass
thx guys,
Mr.T
Old Jul 4, 2001 | 09:41 AM
Check to see if the actual trunk lid that is the cause or not. If it is you can adjust the black pods that is attached to the trunk lid. Turn them so that they stick out more and see if that helps.
Old Jul 4, 2001 | 04:05 PM
acuraracer's Avatar
Ex-Acura Die Hard Veteran
Where are these located?
Dave
Old Jul 4, 2001 | 06:57 PM
My sub ratlles my trunk too!
My trunk is Dynamated and I even have foam stuffed between the back of the decklid (inside behind the ACURA logos). But the last rattle I have is the latch on the deck lid. Where the little hook holds the metal. See if that's it. I might try a strip of teflon tape on the metal part - but it can't be too thick or the trunk won't pop!
Old Jul 4, 2001 | 09:24 PM
acuraracer's Avatar
I tried playing with those black things and it seemed to hel a lot. It sounds like most of my rattling is coming from inside my bumber behind the tag. The tag used to rattle but nothing a little double sided tape does not fix.
Dave
Old Jul 7, 2001 | 12:15 PM
Mr.T's Avatar
Dave
I can't find these either?
Old Jul 7, 2001 | 04:28 PM
StreetEffectz's Avatar
And here's a little tip....if you remove the liner from the trunk lid, you will see a black cable that goes to the trunk release lock...you need to tie wrap that down so it doesn't vibrate and hit the lid.
Old Jul 9, 2001 | 09:21 PM
Mr.T's Avatar
I duck tape the wire down already
Old Jul 10, 2001 | 09:21 PM
rbrown55's Avatar
my trunk is rattling too. i am getting dynomat this sat. mine is rattling on the portion where the acura letters are. man its bad. so ad i keep the bass turned down (FOR NOW). Hopefully the dyno will work.
Old Jul 12, 2001 | 03:43 PM
fahoumh's Avatar
Shogun Assassin
damn......i totally forgot about things in the trunk rattling......oh, what's this "dyno" thing everyone here's talking about? You'll have to forgive me, I'm still kinda new to forum.....
Old Jul 16, 2001 | 02:03 AM
acuraracer's Avatar
Cant we all just go dig around in our attic and steel some insulation from there. Yes, Jerry Rig is right but damn dyno is so damn expensive.
Dave
baelim
May 10, 2018 09:53 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
merc009
Sep 29, 2015 03:06 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
