Newbie: 03 TL headunit wiring
Old Nov 23, 2008 | 11:03 AM
bartekli's Avatar
Hi everyone,
So I've gone through most of the posts I could find with no luck.
My original headunit went south (CD errors) so I bought a used one thinking easy switch....how wrong was I to think that both would have the same wiring harness sockets....
The original headunit has 3 harness sockets while the new one only 2 and the smaller ones don't match up (original has a 14 pin socket while the new headunit has a 12 pin socket). So...the speaker harness plugs in just fine but the Bose amp harness does not fit. The end result is that I only get faint sound (no amp).
Any suggestions on what I should do? Will an aftermarket radio harness solve the problem or do I need to change the amp harness to a 12 pin?
Thanks,
Bart
Old Nov 23, 2008 | 11:52 AM
dreem1er's Avatar
deal with it
when you change out the head you loose the stock sub there is a way of wiring it up though
Old Nov 23, 2008 | 11:54 AM
dreem1er's Avatar
deal with it
LINKS:
keeping sub
audio DIY
Old Nov 25, 2008 | 05:51 PM
dannyr678's Avatar
you can look up at the electrical schematics for both cars and just match up the wires. If you're electronically inclined, this should be a piece of cake. You can also buy the pluggs of ebay for the stock harness and another one for the headunit and solder the wires together, this way you won't have to cut original wires and it will be a plug and play.
Old Nov 25, 2008 | 08:17 PM
kennedyhuynh's Avatar
Originally Posted by dreem1er
I don't think he has a aftermarket radio, i think he bought a used bose radio somewhere. Was the used radio from an 02-03 TL?
Someone can correct me if i'm wrong, but i do believe the 99-01 TL's have different radios than the 02-03's.
Old Nov 25, 2008 | 08:22 PM
fsttyms1's Avatar
It sounds like he bought another stock radio. Problem is it sounds like he got the CL radio which is NOT compatible with the TL.
Old Nov 25, 2008 | 09:55 PM
NSXNEXT's Avatar
Yup Kris beat me to it. You my friend have a CL head unit. Will not work in the TL.
Old Nov 27, 2008 | 05:20 PM
dreem1er's Avatar
deal with it
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
