new system advise needed(pics)
Old Jul 30, 2005 | 11:03 AM
TLEXTREME's Avatar
Missing Machismo
any suggestions in my 00 TL-P? amp wont fit under seat -- best stuff for removal of swirl marks on dark cars!
http://img43.imageshack.us/my.php?im...ture1857ej.jpg
http://img43.imageshack.us/my.php?im...ture1840ob.jpg
Old Jul 30, 2005 | 11:08 AM
dark inspire's Avatar
El Presidente
Welcome!
Thats quite a hefty sub you have there. Maybe you can mount the amp on the side of the trunk, or even on the side or back of the sub box. Depending on if you want to do it yourself or not, you could build a false floor and have the amp sit under.
As for removing swirl marks, check the Wash n Wax section
Old Jul 30, 2005 | 11:13 AM
optomos's Avatar
I=X - optomos
Ive seen the amp installed on the side where the jackstand is. There is a post in here with pics on how it was done, but cant seem to find it. Will post again when I do.
Old Jul 30, 2005 | 11:36 AM
NICKTL's Avatar
i've got the same set up. i am assuming you have a 12 w6. i put my 500/1 under my passenger seat. it fits perfectly snug.
Old Jul 30, 2005 | 11:38 AM
TLEXTREME's Avatar
Missing Machismo
the sub is a jl 12w6v2 amp is the jl500/1 +1 farad capacitor please i would love to build the amp rack on the left of the trunk but need to know what materials to use. the box is ported speciaslly designed for the specific sub so that has to stay. fiberglass is not an option for amp rack. false floor is an option just need good instruction to do it and ill keep you guys updated with pics of the build. might be timely considering im one handed now but i still got some skills. hook a brother up!! instructions pls.
Old Jul 30, 2005 | 11:41 AM
El Presidente
well i mounted my 500/1 on the left side, and kinda ghetto rigged it (it was my first time) but anyways, there is a metal plate on the right hand side which i screwed a board too and then put some wood on the other side (near the taillights) all behind the trunk liner. Then i just screwed the amp to a plastic piece and then that plastic piece to the metal plate and the wood piece. I hope that helps, im sure people here have better suggestions on building amp racks in that location.
Old Jul 30, 2005 | 11:44 AM
TLEXTREME's Avatar
Missing Machismo
false floor might be easier no? any sduggestions on that inspire? what main problems will i run into with this setup ---besides the stock h.u to amp issue im working out now.? too much for the car?
Old Jul 30, 2005 | 12:06 PM
El Presidente
well what's your setop right now, im guessing you are gonna be doing all the work yourself. I have not made a false floor before, but i would guess it would require a cardboard template and the carpeted wood. Also, i would put some plexiglass in the middle tp display the amp, but i've never done it before
Old Jul 30, 2005 | 12:35 PM
dnd2984's Avatar
here is a pic of how my amps are mounted
http://img24.imageshack.us/my.php?im...ture0129br.jpg
Old Jul 30, 2005 | 01:42 PM
optomos's Avatar
I=X - optomos
Thats the picture I was looking for
Heres some more, but mounted on the other side. This was done by StreetEffectz for NSXNEXT
Old Jul 30, 2005 | 04:51 PM
TLEXTREME's Avatar
Missing Machismo
thats the one i like on the bottom any beginning instruction ---besides good luck
Old Jul 30, 2005 | 06:26 PM
optomos's Avatar
I=X - optomos
Here's the thread for the install: https://acurazine.com/forums/audio-video-electronics-navigation-22/behind-scenes-neils-nsxnext-audio-install-194784/
You could ask NSXNEXT
Old Jul 30, 2005 | 08:13 PM
TLEXTREME's Avatar
Missing Machismo
not much info on the amp rack
install
Old Jul 30, 2005 | 09:37 PM
elduderino's Avatar
VP Electricity
I think you can fit that amp under the passenger seat if you shim it up a few mm : )
I had the 300/4 under the pass seat of my TSX with 3 1mm washers and removing the under-carpet padding.
Old Jul 31, 2005 | 09:44 AM
Tyzing's Avatar
I just thought you'd like to see something a little different....it's out of the way and still gives you full access
Here's a pic without the floor in but it gives you an idea of what it'll look like
Old Jul 31, 2005 | 10:36 PM
TLEXTREME's Avatar
Missing Machismo
nice hide and seek amp built the roof from a template ? or what? more info for learners plz thx for the great idea though.
Old Aug 1, 2005 | 10:53 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
mounting to the deck, or back of the seats is a good idea, unless your seat folds down. I also like the side mount. Personally, I usually mount my amps right to the box, so I can run shorter wires. However, in my next setup, with fiberglass enclosure, I'm mounting my amps straight to the trunk bed, and putting a false floor over them. It all depends on what's easiest, and what look you're going for.
Old Aug 2, 2005 | 10:19 AM
TLEXTREME's Avatar
Missing Machismo
well the box is custom so i dont want the oppertunity to screw it up. plus im kinda proud of the amp. and would love to show it. what kinda materials would i use for mounting and making an amp holder up top or on the left of the trunk.?
Old Aug 3, 2005 | 04:39 PM
TLEXTREME's Avatar
Missing Machismo
bump still looking...
Old Aug 5, 2005 | 11:21 AM
TLEXTREME's Avatar
Missing Machismo
well my wifey went out and got it all hooked up while i was gone (happy birthday to me) so ill post pics when she gets home today! shes gotten to drive the car more then i .
Old Aug 5, 2005 | 11:32 AM
Fluid Grease's Avatar
I Just Con't Drive 55 Mon
HAPPY BIRTHDAY DUDE!....Props to your wife man ....g
Old Aug 5, 2005 | 11:49 AM
El Presidente
Happy Birthday! and Congratz
Old Aug 8, 2005 | 03:29 PM
TLEXTREME's Avatar
Missing Machismo
now the car's getting the front end repainted (from a kid on a bike) can't have my NBP tl all scratched up like that. so well see how it all works. the rims come as soon as i sell my old ones.. then ill be happy for a little while.(very little)
Old Aug 14, 2005 | 01:07 PM
TLEXTREME's Avatar
Missing Machismo
quick fix with the system finishe for now thx for all the advise guys hope yall like it
Old Aug 14, 2005 | 01:08 PM
TLEXTREME's Avatar
Missing Machismo
[img=http://img217.imageshack.us/img217/8851/picture2434iv.th.jpg]
if that didnt work then ...
http://img217.imageshack.us/my.php?i...ture2434iv.jpg
Old Aug 14, 2005 | 01:48 PM
elduderino's Avatar
VP Electricity
So how is the JL amp secured to the trunk liner?
Old Aug 14, 2005 | 02:59 PM
optomos's Avatar
I=X - optomos
Ya I wana know to. I like it free standing like that.
Old Aug 14, 2005 | 10:33 PM
TLEXTREME's Avatar
Missing Machismo
let me go take a looksee-- i still cant find my capacitor i know they hooked it up but i cant find it----thats either good or bad depending on your tastes. gimmee a second... looks firm sounds solid wood bolted to metal?
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
ExcelerateRep
Dec 11, 2015 12:58 PM
