Behind the scenes of Neils (NSXNEXT) audio install....
We applied LOTS of cascade dampening material which is the BEST "MAT" I have EVER used...made some spacers for the front CDT components, all doors, trunk, under rear seat and deck lid are all cascaded....MORE PICS TO COME!
MORE PICTURES
The amp and cap are covered with a plexi and carpeted cover. Fully removable but there to prevent things like golf clubs from beating up my amp.
In the one picture you'll see that I was able to keep my trunk tray. I cut a section out of it so I can still use it. That thing is a lifesaver.
Nice and very simple with lots of room still. How does it sound? Does it say 'made in Germany' on the amp like the Brax's? What did Ron use to cover around the amp?
When tuning it in you might want to try reversing polarity on passenger's midbass driver only- I felt it made a difference in moving the soundstage towards the front of car a bit more and widening the 'sweet' spot.
Todd,
Yeah it sounds amazing compared to the stock system. One problem is that Kirk thinks the voice coil is blown in the sub. Ron mentioned that it would not get very loud without making some strange noises. Definitely no fault of Ron. I gotta run out the see Kirk tomorrow to see about getting a new one. Even without the sub it still sounds great.
I may try reversing the polarity to see if it sounds better.
Bad to hear but I'm sure Kirk will take good care of you. Take what you need to hook a new sub back in at his place, then talk Kirk into listening/tuning with you. He's been doing it professionaly for 20+ years, so he's got the ears for it. Kirk and Ron should hook up - Kirk should have a recommended installer in his area.
Originally posted by 260 HP
Hey Ron. how many layers of Cascade did you put on?
Originally posted by spiroh
Give us a review on the CDT sub. I never heard this before, and Im wondering how it sounds.
Initial review, in the Element Enclosure, it is unbelievably tight. No mushy bass for me.
Originally posted by Mike H.
Nice install. Which Cascade material did you use? Have you heard of RAAMmat? Does it pretty much do the same thing?
Originally posted by NSXNEXT
Yup pretty much the same thing. Cascade doesn't have an odor like Dynamat and weights a heck of a lot less.
yeah!!!
what was the total usage of the cascade? did you use a whole shop pack of 42 sqft? i bought 2 packs of the stuff. i haven't installed it yet, but i was wondering if i got enough to do the whole car? so how much did you use?
hey there Inf4life!!!
i got the cascade from http://www.carstereopro.com/dynamat.html
i got the 42 sqft shop pack:
the vb2 for $144
the vb2-hd for $199
they're pretty prompt and good about delivery.
so NSXNEXT!!!
did you cover the WHOLE trunk? the bottom, sides and lid? and does the road noise dissappears? and the stereo sounds better?
thanks!
the vb2 for $144
the vb2-hd for $199
so NSXNEXT!!!
thanks!
Originally posted by ArchAcuraTL
so NSXNEXT!!!
thanks!
so NSXNEXT!!!
thanks!
Ron covered the entire bottom of the trunk. Did not do the sides.
Originally posted by Mstyle
Hey Ron or Neil,
Can you just put all that padding in the trunk area and that will reduce road noise???????
Hey Ron or Neil,
StreetEffectz or NSXNEXT:
I'm about to do an installation of the 6.5" CDT HD63DT-S seen in this thread. I'm interested in knowing if there are any problems in installing these speakers in the front doors. I see that you used 3/4 inch MDF to make room for the larger size, but did you have to alter the grills in order to make room for the bracket that holds the tweeter? Any helpful suggestions in getting these speakers to fit correctly will be greatly appreciated.
The problem I'm having is the space for my pair of MB Quarts. I cant see any way they are going in my door without taking a saw to the rim of the old speaker area. I need another inch it looks like in radius for these 6+1/2 even with a spacer. Did you have to cut the sheet metal to drop yours in?
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
