new amplifier wiring
Old Jan 17, 2003 | 01:20 PM
AQUI NO!'s Avatar
It's not over yet
when adding a new amp to the cl will u need to rewire the car or can you use the existing wires used to power the amp and speakers?
Old Jan 17, 2003 | 04:01 PM
AQUI NO!'s Avatar
It's not over yet
any one
Old Jan 17, 2003 | 04:46 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
try using a distribution block to slpit off your power wire i have this done to my car but i think i am changing it back since i think thats why my speakers are giving me ground noise. i have a 4 awg to a dist. to 2 8awg wires and then to the amp but im only using one amp so i have an extra slot but someone told me i should use the 4awg and it should get rid of the noise but havent had time to check it out yet but look into a distribution block
Old Jan 17, 2003 | 05:10 PM
mantis23's Avatar
Moderator Alumnus
You _can_ use the existing wires.. but if you are an audiophile, I'd highly recommend rewiring your system.
Old Jan 17, 2003 | 06:16 PM
SilverKnight's Avatar
Retired. Not available.
the existing wire is like 26 or 24 gauge. The insulation will start melting if you use it to power aftermarket amp.
Old Jan 17, 2003 | 09:26 PM
icy CL's Avatar
run a new power wire from the battery....use 8 or 4 gauge. the stock wire for the bose amp is too thin. as silver says...it will get very hot....of course depending on the aftermarket amp you use. still, better to run a new power wire form the battery. NO! run a new power wire form the battery.
4drviper
Apr 23, 2025 07:13 PM
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
