New alternator
Old Oct 21, 2002 | 11:14 PM
dnd2984's Avatar
New alternator
first what is the amps on a 2001 TL-p. I have 2 amps a 500 watt for the bass and 300 for my mids and highs. I have 800 watts RMS power in the car. I have a one farad cap and was wondering my light still dim. I mean they dont dim as bad as they use to when i didnt have the cap. At higher volumes of around 27 (35 is the max volume on my alpine deck). I thought a cap would get rid of the diming light problem at any volume levels. How much does a higher up amp alternator run. And also am I doign any damge to the electrical system.
Old Oct 23, 2002 | 09:14 AM
dnd2984's Avatar
come guys someone has to have some knowledge about the alt.
Old Oct 23, 2002 | 10:56 AM
96TL's Avatar
Ex-Mod
That setup you’re running shouldn’t be dimming your lights. 800 watts is your max power which I doubt you use. Lets say you do though, then your drawing about 55 amps. Most likely its less than that. The stock alt in my first gen 3.2 TL is 110 amps. Yours is probably around that same number. If it is, then you should have enough power. I would check the ground. Make sure its not too long and make sure its grounded to chassis.
For a good high amp alt, call up Ohio Generator. They wanted $400 for my first gen alt re-wound to 200 amps.
Old Oct 23, 2002 | 08:51 PM
dnd2984's Avatar
Well i think I am drawing about 70 amps. I had a 60 amp fush and the audio place had to change it to a 150 amp ANL.
Old Oct 23, 2002 | 10:26 PM
marinalk1's Avatar
i have the same problem, the only thing that is dimming is my alpine headunit, i have a 2 farad cap also. Nothing else dims except for the headunit. I learned to live with it and it doesn't really bother me any more. If theres a way to fix that please respond.
Old Oct 23, 2002 | 11:08 PM
96TL's Avatar
Ex-Mod
dnd2984, well you might need a new alternator after all. Like I said, Ohio Generator can do it for you. They do great work at a reasonable price.
marinalk1, how many amps do you have connected to the remote signal from the headunit? Maybe they're drawing too much power. I think its okay for you to use a low voltage relay as a remote signal using the radio as a trigger but I'm not sure. You can also try grounding the radio somewhere else.
Old Oct 24, 2002 | 04:45 AM
dnd2984's Avatar
What unit do u have. I have the cda7897 and it Dim now and then even if the music is really low. It starts dim for about 30 seconds and then stops.
Old Oct 24, 2002 | 04:46 AM
dnd2984's Avatar
96 tl thanx for the help i am gonna look into ohio gen.
Old Oct 24, 2002 | 01:04 PM
TopGum's Avatar
check out this thread:
http://www.acura-tl.com/forum/showth...threadid=47792
Old Oct 24, 2002 | 03:57 PM
marinalk1's Avatar
I have the 7893 and mine dims only when it is really loud. Even if i dont have my subs on it still does it.
Old Oct 29, 2002 | 01:04 PM
96TL's Avatar
Ex-Mod
BTW, I found another place for high amp alternators. They’ll do my first gen alt to 180 amps for $250.00! Its www.mralternator.com Its not listed on the site. Just give them a call and ask for Tom. I don’t know if the workmanship is as good as Ohio Generator though.
Old Oct 29, 2002 | 08:52 PM
dnd2984's Avatar
Thanx bro I will defiently be doing that, and so will my friend. HE killed his alt wit a 1000 watt zapco and 3 JL 12's
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
mars
Sep 28, 2015 11:03 AM
agupta3224
Sep 22, 2015 08:08 PM
