Neon under dash
Old Jul 17, 2002 | 06:17 PM
Neon under dash
I wanted to put blue neon under my dash. Not sure what size bulb to buy. Has anyone done it yet?
Old Jul 17, 2002 | 08:48 PM
2007AcuraRL's Avatar
Not sure what you mean by what size "bulb" to use. Neon comes as a tube, sold in various lengths. a 1 foot tube would be more than enough.
Old Jul 17, 2002 | 09:46 PM
hey what do you think about neons under the car, white ones?
Old Jul 18, 2002 | 12:10 AM
Been done a zillion times. Not sure if its an outdated thing to do at this point??? I did see a guy that used neon behind each wheel. it was aimed to be shinning through the disc brake and caliper, rather than aimed on the ground. (Done with a clear tube around the neon, painted all around except for a single slot of light to come out) That was interesting, but i guess you'd have to clean the thing practically every day.
Old Jul 18, 2002 | 09:36 PM
noleaf74's Avatar
I have 15" tubes under my dash
Old Jul 19, 2002 | 10:25 AM
futuregs's Avatar
9th Gear
Here are pics of my neons in my Lexus GS:
http://www.clublexus.com/forums/show...ighlight=NEONS
Old Jul 19, 2002 | 10:17 PM
calvinpham74's Avatar
do we need a swith when we do this, so we can turn on or off? Also do u need a fulse for this instead it might burn on you.
Old Jul 19, 2002 | 10:27 PM
FRESHV6's Avatar
asiankidd has them on his car.. check out his thread, floating around somewhere.
i just recently bought some 10" red ones
Old Jul 20, 2002 | 11:14 PM
KaMLuNg's Avatar
u can always wire them to turn on when u start ur car but that is a waste cause in the daytime u won't see them newayz... it would be better to wire them to a switch so u have the capability of turning them on and off when u want... and yes the switch should be on a fuse... u don't wanna risk a short going around ur car... well actually i never wire it without a fuse... just tap into the parking lights.. that is the easiest..
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
2Quik
Sep 23, 2015 01:03 PM
eastcoastguy
Sep 23, 2015 06:29 AM
