Neon Install Help Needed
I want to wire two small blue neon crystal tubes under the front dash. Can someone please give me detailed instructions and if possible install pics on how to do this. I would like to wire them so that I can control them via switch.
Thanks!
Thanks!
Some people’s minds are so closed about "rice." Neons are the Sh!t. Ok, I ran an extra power line into my car with a fuse for all the neons that I plan on putting in my car. From there I added a switch [actually it's a music sensor that beats to the bass]. The neons are hooked up to the sensor and then secured at any means necessary. At the moment I have them under the dash and in the back seat foot wells. It really isn't that hard all you need is power and a ground.
8th Gear
WARNING: I put neons in my car and it caused my car to have SRS (airbag) problems (see my thread)...the dealership guy says the transformer in the neon tubes creates an electrical field which messes up the frequency of the airbag sensors causing the srs lights to come out..the dealer guy could be bsing....but be very careful and wish u luck that u dont have the same problem i had.
I think the guy was bsing. Pretty much every electrical device puts out a field. Say, you put in a radar detector. It causes a field, but I haven't heard of any srs problems. Might have been b/c of which power line you tapped into.
BTW: Neons are not rice. They are nice.
neon lights
I just installed neon blue lights under my dash (2003 A-Spec) and the next day my SRS light came on..i only wired them to the park lights and grounded them out ...very simple looks great but SRS is on ..dealer told me that it may be the seatbelt harness sensor ...coincidence??i am taking it in on wednesday we will see.
are you trying to use the neon lites as footwell lighting? well you can tap into the dome lite wiring harness that is located on the passenger side fuse box...then the neon lites fade just like the dome lite...pretty koo...oh yeah...you can add a switch if you want to control the neons...but if you want them to turn on without your doors open, you need to add a second ground...just do a search for the wires you need to tap...
laters
laters
wait...the ground controls wehter it goes on and off?...i thought it was a the postive...so when im hooking up neons to work with the light in my trunk..i suould use the negative wire from the light or find another gorund?
i think the dome lite uses a passive ground for when a door is open the circuit is complete then the dome lite turns on...so you need a second ground if you want to turn on the neons w/o opening the doors....i think thats it..read it in this forum a while ago...search for footwell lighting...
srs indicator
Took the A-spec in today for undercoating and to service the srs indicator light ...they told me it was infact the seatbelt harnes that caused the problem.. they replaced it and it didnt come back on ..even with my neon lights...time will tell...Also got my windows tinted looks amazing
Originally posted by njtls
yeah..your right...if i use a dirrernt ground they wont turn off....hmm...so is it safe to run like 3-4 neons off the the wires....they seem so thin....i dont want them to melt or anyhting
the dome light wiring and the trunk light wiring should be the same right?..im gonan be runing1 20inch sound activated neon a strobe and 2 6inch mini neons....
hmm i ordered the 20inch in red and the 6inchs in yellow...you guys think that wpould give me a good effect...im going for a firey look....
let me know how your firey look comes out...cant wait to see the pix...laters
TLDude876
12-28-2016 03:18 PM
nuldabz
09-03-2015 05:49 PM
