need sub box help, will this work?
Old Jan 2, 2002 | 12:39 PM
systek's Avatar
http://dreamwater.org/systek/acuratls/DVDHACK3.html
look towards the bottom of the page...the subs are facing each other, it will be sealed so all the sound comes through the ski hole. is there a set amt of space between the subs that will allow this to work?
would it be better to form a wedge? please let me know...
Old Jan 2, 2002 | 01:13 PM
Wampum's Avatar
I think you would have to calculate your airspace in between your two drivers. I think you will get a "horn loaded effect"
Ron are you out there to answer this?
Old Jan 2, 2002 | 05:25 PM
Austin519's Avatar
You're using a Single Reflex Bandpass Enclosure with that. With that in mind, you will need to make sure to calculate the port volumes that you have now created using the ski hole and fill accordingly. Not properly tuned that may sound quite bad. So you will have to tune the port to the specified frequency the manufacturer gave. I would assume that port is, as it is now, "tuned" much lower than factory spec., leaving you with muddy bass. Hope this helps.
Austin519
Old Jan 2, 2002 | 05:28 PM
Austin519's Avatar
systek:
Oh yeah, this site's pretty good:
http://www.diysubwoofers.org/
Austin519
systek's Avatar
Austin519
actually if you are right about the port effect, this is very very bad, since the solo's that i have are NOT to be ported....i guess i will have to experiment and just go by ear
Old Jan 2, 2002 | 08:18 PM
Austin519's Avatar
systek:
That's what I usually do. Just a suggestion...put some mesh over that hole...make for a stealth install...
Austin519
Old Jan 3, 2002 | 08:35 AM
systek's Avatar
systek:
Austin519
mesh where? in the ski hole, i want to leave it to where you can see the subs, up in the rear deck, i plan on using the factory covering...
Old Jan 5, 2002 | 07:51 PM
Austin519's Avatar
systek:
Ah...well then at least vinyl wrap those wood pieces....don't just leave them like that...or paint them...I think anything other than wrapping them would look terrible ...
Austin519
Old Jan 7, 2002 | 12:04 AM
systek's Avatar
systek:
Austin519
ummm, no.
like i said, im experimenting, so that means looks doesnt mean squat...! when i decide on the final install setup and start putting that together...then i 'll worry about looks as well.
cycdaniel
Dec 17, 2019 10:58 AM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
alan_rich
Sep 9, 2015 11:38 AM
bymotion
Aug 31, 2015 05:00 PM
