need mono amp help
Old Sep 16, 2003 | 09:15 AM
03typeS6spd's Avatar
misanthropist
need mono amp help
I need some help, I am trying to put a single 10 in the type S and no one seems to know anything about mono amps. I have a hifonics bx1000D amp that is one ohm stable, but I don't know what specs of dvc coil to get. If I run a dvc dual 4 ohm in parallel and then "bridge" it into the single channel will that run at one ohm??? or do i need to use a dual 2 ohm speaker that will bridge both coils to one ohm??? Need some help! I am ready to say screw it and just go buy a nice simple two channel amp like I have always had!
Old Sep 16, 2003 | 10:18 AM
proaudio22's Avatar
-S namyaC-
If your amp is 1 ohm stable, get a dual 2 ohm sub, and wire the terminals together (+red to +red, -black to -black). That puts the 2 ohm coils in parallel, and gives you a 1 ohm load. If your amp has two sets of terminals (incase they thought you might use more than one set of wires), you can use a set for each voice coil - it'll tighten up the amp's control of the sub by helping the amp keep all of it's damping factor.
Old Sep 16, 2003 | 10:23 AM
misanthropist
Thx proaudio
ohhhhh, finally someone who knows, that is why the pictures had "two" channels showing, thanks that is exactly what i needed
now i have one more question, has anyone else used the cable link thing from linkmeup.com , i called them and the guy was saying it wouldnt work right just using the cable link, but that i needed the pd2 to go with it, is this true or his he trying to get me to buy the $100 piece i dont need (which is what i think)
Just trying to keep the install as clean as possible
4drviper
Apr 23, 2025 07:13 PM
Aug 15, 2019 12:58 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
