Need help running wires!!
Old Dec 10, 2001 | 10:53 PM
Quick Silver's Avatar
I am installing a JL-Audio amp (500/1), and i am having trouble running the wires. The wire is 4-gauge (hella thick) and i can't seem to get it through the firewall, from the engine into the cabin. Does anybody have any recommendations on a simple method of getting this done?
Thanx in advance!
Old Dec 10, 2001 | 11:17 PM
SilverKnight's Avatar
Retired. Not available.
Re: Need help running wires!!
Thanx in advance!
check the link in my sig. The hole is big enough for 1/0 gauge.
Old Dec 11, 2001 | 07:17 AM
icy CL's Avatar
once you've found the hole, start with a smaller gauge wire, like 8 gauge. tape the 4 gauge to one side of the 8 gauge, the other side of the 8 gauge, run through the firewall first. then slowly pull till the 4 gauge goes through as well. it might help if you tape a ballpoint pen at the side of the 8 gauge that you will be inserting first through the firewall. that's what i did and it made it a lot simpler
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
VA2000TL
Oct 2, 2015 08:26 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
