CL: NEED HELP! ive been searching for 5 hours still nothing
Old Jul 1, 2011 | 02:27 AM
Bham03TLs's Avatar
Exclamation NEED HELP! ive been searching for 5 hours still nothing
So i just purchased a CL-S non-navi and i have TL-S with navi and i wanted to swap it over but every thread i found on here the pics or diagrams have all been removed. thanks in advance. plus any advice on what to do about connecting an amp and subwoofer to the factory system would be helpful. im a little confused about which speaker wire to tap into in the back or if there is a way to go straight from the head unit? because i would imagine the bass would only hit from the side that the speaker and sub were connected. if that makes any sense... like when sometimes songs go from one side of speaker to the other.
Old Jul 1, 2011 | 05:26 PM
Bham03TLs's Avatar
Any help is appreciated... A link to a non-expired thread would be very helpful
Old Jul 5, 2011 | 03:35 PM
aznboi2424's Avatar
There are only a few wires that connect the navi system to the audio system. You will just use the stock CL audio system, no need to swap over the amp or EQ or radio from the TL.
As for adding an amp and subs to the CL, you will need an in-line converter. That converter will convert the speaker signal into an RCA signal. Then connect that to your amp. I tapped into one of the rear speakers.
Old Jul 8, 2011 | 06:20 PM
Bham03TLs's Avatar
Thanks this helps out alot
quanaman
Jan 9, 2023 07:33 PM
IBankMouse
Jun 13, 2020 12:53 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
