Need Help on 6X9 and AMp install
Old Jul 31, 2006 | 02:29 PM
vernieman21's Avatar
5th Gear
I just got done hooking up infinity 6x9's to a rockford amp. I ran all the wires necassary and the amplifier was working fine but had no power to the 6x9's. After messing around wit the wires i got it to work for lik 5 seconds and went off. I have no idea why the speakers won't work please help.
Old Jul 31, 2006 | 02:33 PM
KaMLuNg's Avatar
check the polarity of your lines... and also i would try other speakers to see if the speaker is the problem or the amp is your problem... diagnose from there...
Old Jul 31, 2006 | 02:37 PM
5th Gear
i hooked the 6x9 up to another car n they worked so its not the speakers so im guessing its something with the wiring.
Old Jul 31, 2006 | 04:13 PM
phipark's Avatar
Not Asian
It's the amp, something is fried inside. You will be able to get it warrantied unless you bought it off ebay.
Old Jul 31, 2006 | 04:15 PM
BEETROOT's Avatar
Yeehaw
Check the fuse.
How do you know the amp was working fine if the speakers weren't working?
Old Jul 31, 2006 | 08:37 PM
KaMLuNg's Avatar
try hooking up different speakers to your amp.. if they don't work it is def the amp or connections...
AndrewS
19
Mar 14, 2024 06:59 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
