NE1 have their amp mounted on the back of thei sub box?
Went and checked out a shop on installing my amp/sub and that is what he suggested. Install for $150.00.
Any comments or advice welcome.
Thanks.
Thanks.
Basically installing the amp and mounting amp to box. I will have to shop around some more. Just that it is hard to given up my car to someone that may royally screw up my car electrics....
I was going to say it was a little pricey but if it's a well known trustworthy shop it's worth the money..
ok thanks Jonesi..
Is there anything I can buffer the amp with on the box?
Just be sure to go to a very reputable place and don't worry too much about cost it's well worth it..
Where area do you located? Maybe someone here can recommend a good shop.
If its a quality amp and you plan on having it for a while I wouldnt mount it to the sub box. If its a cheap amp then go for it.
150 is not a bad price if it includes running power wire from the front ot the rear also.
I keeps it real
1 Post
I dont know if you're up to it Eggplant but the DIY's for amp and sub install's around here make it childsplay. If its worth it to you to save the $150, you may just set yourself aside a Saturday and have some hot man on car love.
It's for his Camry but yes same concept... Just spend the $100+ at a reputable shop. It will be worth it..
Will spend the money and get it done right. Thanks all. I am clumsy with DIY stuff and will screw it up without a doubt...
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
