Navigation A/C Climate control HELP !
Hey guys I have a question, this weekend I converted my TL from non navi to navi. Everything is working fine except the. A\C controls. I plugged the pins in the correct spots but the AC still does not come up.
When you go into the diagnostics for the navigation the AC portion is red and the top says NG.
Could this mean that the wires are not making contact or I have a bad screen? Is the A\C button suppose to show the climate control when pressed even if it is not connected? Or will it show the climate control only when it is connected
Ok sounds good, i will try to wire it again on Friday. i think maybe the pins are not making contact with the pins in the climate control unit.
another question, if i just leave my climate control on auto will the AC compressor come off automatically?
I tried it last night with the pins and it didn't work, it could be a faulty monitor. i will leave my climate control on Auto
when you leave the climate control on auto does the ac compressor automatically come off when the heat is on?
navtool.com
31
Nov 16, 2015 08:30 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
