Nav to DVD HELP B4 MY CAR DIES!!!
SOLD 9/11/06 Parts 4 Sale
Ok i just installed the nav to dvd converter from dom (plug and play one) but im having trouble with one thing... the converter and the FM modulator stay on after i shut the car off!!...i know its because the wires are run streight to the battery but i got power from a capacitor which i used to power up my subs and amp....the capacitor goes streight to the battery but when i shut my car off it used to go off too since it did not get a radio signal...now that i have the converter hooked up to it, it just stays on.... I think the only things that stay on are the LED'S to show that it is recieving power but it is still drawing power from the battery and i dont want to have a dead car in the morning. Does anyone have any solutions besides hooking it up the the ignition and splicing wires because i realy hate messing around with wires in my car?
Thanx
Thanx
Thanx
Thanx
Hope that helped.
Drivin' it till it dies!!
Originally Posted by funkbucket007
You've got it tapped into constant power & it needs to be tapped into switched power (i.e doesn't get power until the ignition is on). Tap into the remote turn-on for your amplifier for a quick fix if it's in the trunk. The Nav/DVD convertor I have is in the console, so I tapped into the 12-volt input (which is switched) that's in the console.
Hope that helped.
Hope that helped.
I agree with all but one thing, I wouldn't use the amp remote wire. Doing so could draw too much power from the head unit and will damage it. IT IS ONLY A QUICK FIX!--like Funbucket007 stated.
so what should i do because its so simple of a problem but so hard....i dont think i can put a swtich on my 4 gaugue wire that powers up my capacitor, amp, nav to dvd conervtor, fm modulator...i dont know where else to get power from other then my capacitor and i dont want to splice wieres....
Originally Posted by nismo
long term solution? buy better products.
WTF is wrong with these products that I should know about?
The problem im having does not concern the product its about my wiring and where I should put a switch. These products are not supposed to have a switch if thats what you are talking about. Its all about the way you wire them...
Ex. My sound system cost me like $600 just for the subs and amp...they dont have a switch in them...you have to wire them a certain way so that when you shut your radio off the sound system goes off too...
ok how bout sound wise... i have the fm modulator not a cheap one but im hearing sort of a whisteling noise (peeeeeeeeee) does it have to do with my ground wire or something or is it always ganna be there?
Soul_Deamon
11-13-2018 04:44 PM
andysinnh
09-05-2015 11:38 PM
