My redone system is BAD!
Old Jan 8, 2002 | 10:21 PM
01blkCL-S's Avatar
So I am rich, big deal!
It was finished around a week ago. I have been enjoying it ever since. It has to go back for some work to the underhood wiring but everything else in the system is done.
The pictures of the system cannot do it justice. This is truly something that needs to be heard and felt in person.
Let me tell you my goals for the system before I tell you about the system.
From the inside of the car I wanted it 100% stock looking. I wanted nothing different at all.
I wanted realistic imaging. I wanted it clear and undistorted all the way to the max level.
I wanted to be able to fit a full-sized stroller into the trunk as well as misc packages with no problem.
I wanted it LOUD with a ton a BASS.
I got it all.
Old Jan 8, 2002 | 10:24 PM
01blkCL-S's Avatar
Here are the amps:
Sunk into the trunk floor
Old Jan 8, 2002 | 10:41 PM
01blkCL-S's Avatar
Here is the whole trunk
What this is is 2 Xtant amps. 1 is 4 channel running all the MB Quartz Seperates in the car and the other is the 1001 Mono-Block D-Class Sub Amp. I had the Cigarette lighter unit redone to be the controll knob for the sub level.
The subs are the new Xtant Alum Subs. They are dual Voicecoil. They are in a 4th order bandpass box with the port the excact size of the ski pass. That means that 100% of the bass enters into the passenger compartment. I have no rattles or viberation sounds on the outside of the car at all! I have the port tuned to 6db up at 47hz.
I have been a sealed box fan forever. This is truly my first bandpass box. I am SO amazed. When the system is turned up loud I cannot read street signs.
Old Jan 8, 2002 | 11:33 PM
hiepdocl's Avatar
CL first
that looks tight, clean.I like it ! hope you enjoice.
Old Jan 8, 2002 | 11:39 PM
hiepdocl's Avatar
CL first
that looks tight, i like it. Hope you enjoy.
Old Jan 8, 2002 | 11:42 PM
hiepdocl's Avatar
CL first
Originally posted by hiepdocl
that looks tight, clean.I like it ! hope you enjoy.
Old Jan 8, 2002 | 11:45 PM
hiepdocl's Avatar
CL first
sorry spell wrong.
Old Jan 9, 2002 | 12:03 AM
dajuice27's Avatar
In Da LBC with Snoop Dogg
DAYUM!
You gotta get a sound file for that one. We all should hear that with some 808 behind it.
Old Jan 9, 2002 | 09:26 AM
JasonT's Avatar
Looks nice, how much was it? Do you still have a spare tire? or jack?
Old Jan 10, 2002 | 04:15 PM
01blkCL-S's Avatar
No spare / no jack. Who needs it? I have both AAA and Acura Roadside.
Old Jan 11, 2002 | 07:25 AM
JasonT's Avatar
Well I do Had 3 flats in 2 months on my Explorer. Nice setup though.
Old Jan 11, 2002 | 12:16 PM
Bluto's Avatar
Find beauty in dissonance
Headunit
Did you keep the stock headunit? If so, how do get a signal to the Xtants amps?
I know the headunit puts out .5 volts and the Xtants can use a signal as low as 120 mVs. I was wondering if you felt using a line driver was necessary.
BTW, install.
Old Jan 11, 2002 | 05:32 PM
01blkCL-S's Avatar
Re: Headunit
BTW, install.
You are right. I questioned my installer on this as well. We tapped into the low-level signal right before the amp in the trunk. He then just spliced a set of RCA's right onto the wires then directly into the amp.
I thought it seemed like a bad way of doing things. The installer said it just doesn't matter with the Xtant amps. I can turn the volume all the way to the max and everything is clear as a bell. I guess he knows what he is doing.
I am planning my new system I am putting into the new 4.4 X5 I just ordered. It is going to be a complete DVD system with screens in the headrest and all that!
Old Jan 12, 2002 | 11:00 AM
KCPreki11's Avatar
Rich bastard
Old Jan 12, 2002 | 05:22 PM
JasonT's Avatar
That's exactly how my basslink gets it's signal. Just spliced some RCA's into the wire coming from the head unit, before the factory amp. Works great!
Old Jan 15, 2002 | 12:01 PM
cls858's Avatar
nice setup. the goals you wanted with your system are about the same as mine. around how much did all that cost you.
Old Jan 15, 2002 | 08:17 PM
langjae's Avatar
do it yourself, !
I was thinking the same, but all AAA does is come and change your tire for you. If you get a flat or something, they're gonna have to tow your ass....
Old Jan 16, 2002 | 09:14 AM
01blkCL-S's Avatar
Well I bought everything a different times as well as traded up speakers along the way. I also choose to go with high-end equipment. I do think the amps could be replaced with something less expensive and still have the same results.
I spent around $7,000 for everything
Old Jan 16, 2002 | 07:45 PM
aaron's Avatar
SILVER
all Xtant X series amps have line drivers built in therefore there is no need to use in line converters/internally there is a five way adjustment for left and right
mada51589
Jan 9, 2025 04:40 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
scionxb3003
Sep 6, 2015 12:19 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
