My Amp keeps...
Old Jun 20, 2006 | 11:32 AM
Jezek's Avatar
I
My Amp keeps...
...overheating. So annoying. I'll be driving down the road for like 20 minutes with the system up, and it'll just shut off for like 4 minutes, then come back up for a few minutes, then back off, etc.
It's a RF 1200 watt amp. I have it wired up to 2 12's. I used to have a 600 watt RF amp that did the same thing, but more often. SO I replaced it with this amp which hits hella harder, but I still have the same issues with overheating.
Is this common?
Anything that can be done to help this?
Any help/input would be appreciated.
Thanks.
Old Jun 20, 2006 | 01:55 PM
Mach30SiR's Avatar
Bagel Bomber
how do you have your subs wired? to what resistance?
Old Jun 20, 2006 | 02:05 PM
c0v3rr1d3's Avatar
how and where is the amp mounted? this use to happen to me cause i had the sub amp mounted verticly in between the 2 10s in my buick. Only way to stop it from overheating was putting a 120mm fan above it that would run when the amps where on to cool it.
Old Jun 20, 2006 | 03:15 PM
rubberduckee30's Avatar
what size fuse are running from the battery to your amp?
Old Jun 20, 2006 | 09:37 PM
FL3.2TL's Avatar
Just chillen..
How is your setup ran? Using a LOC?
Old Jun 20, 2006 | 11:05 PM
PenancE's Avatar
does ur deck shut off also?
i had a messed up deck, safety would hit in, first time it smoked like crazy, safety hits in and cuts off bout 30 min later...could be the deck.
Old Jun 20, 2006 | 11:30 PM
stic2it's Avatar
My RF recently started doing this, I think there is a little problem with the amp. No way I overheated my amp in 20 min just powering one 8in jl w3 I have been thinking about switching too something else...It is one of the most annoying things in the world, for the amp to cut in and out every 4 min...Where are you at? I'm in So Cal....On a hot morning I rode for two hours no problem...much cooler night time, my amp was done in 30 min!
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
