Mercman Factory Amp Harness
Mercman, if you're out there, I could use a factory amp harness if you've got any available. I tried to send a PM but the forum is blocking me for some reason.
I've got an 09 TSX non Navi and I'm getting ready to start upgrading the audio system. I'm going to start with a 5 Channel amp to power the stock speakers and 8 inch sub mounted in the rear deck.
Thanks,
Rick
Thanks,
Rick
You need to have a few posts before you can PM. I will be making more harnesses soon. I have to reorder some parts and I am working on some other projects that will influence exactly what I order. I will be making more harnesses so sit tight, just looking at ways to make them better.
jeff
jeff
I’m almost certain that the tech package DLS system is completely different and won’t work with my harness. I have not investigated the new non DLS system but we can start with the wiring diagram and a photo of the factory amp and go from there.
I’m not sure if I’m going to do the 09 because I’m not sure I want one.
OP if you can access your amp and take some photos we can start there.
jeff
jeff
SNAFU
jeff
jeff
Anyway, the reason I'm posting, I had an '09 TSX the other day as a loaner while having some warranty work done....I freaking loved it. Handling and performance were about the same...hard to tell a difference, but the styling upgrades inside and out were very nice. If it wouldn't cost so much to take everything out my '06 and reinstall it in the '09, I'd be driving it still today. Yes...it is that nice.
Guys..don't brush off the new TSX...just go test drive one. You'll like it. And mercman..stop being lazy and make these guys a harness!
Later....
*** PLEASE HELP, ANYBODY ***
First
The 20 pin harness for the speakers that you pull out of the factory amp.
Does anyone know what wires are for the drivers side woofer?
Or even better if someone has a diagram stating what all the wires are on the 20 pin connector?
Second
Where is the best place to run the amp power wire from under the hood to inside the car? In othe
Third
where and how do you guys recommend doing the ground for the amp?
First
Second
Third
Your a life saver I looked everywhere and couldn't find it!!!
I thought the two connectors going into the amp were a 14 pin (where I plug mercmans cable into) and a 20 pin not a 26 pin?
Need more room in
my bad, here's the tsx one..
https://acurazine.com/forums/showthr...ghlight=sticky
Cavity Wire Connect to
A1 YEL/GRN Radio switch (Amp.)
A2 YEL/RED ACC (main stereo power supply)
A3 GRN/RED Radio remote Switch
A4 RED/WHT (Security inout)
A5 LT GRN Stereo Amplifier (Right rear speaker (+))
A6 BLU Stereo Amplifier (Left rear speaker (+))
A7 BLU Stereo Amplifier (Front passenger's door speaker (+), Right tweeter (+))
A8 RED/BLU Stereo Amplifier (Driver's door speaker (+), Left tweeter (+))
A9 RED/BLK Lights-on signal
A10 WHT/BLU Constant power
A11 BRN Radio remote switch ground
A12 BLU/RED Navigation unit (RG GND)
A13 WHT Navigatoin unit (RG L+)
A14 --- Not used
A15 PUR Stereo Amplifier (Right rear speaker (-))
A16 PNK Stereo Amplifier (Left rear speaker (-))
A17 RED Stereo Amplifier (Front passenger's door speaker (-), Right tweeter (-))
A18 YEL Stereo Amplifier (Driver's door speaker (-), Left tweeter (-))
A19 RED Dash lights brightness controller
A20 BLK Groung (G504)
LEFT REAR SPEAKER
Code:
+ PNK* - BLU/YEL*
RIGHT REAR SPEAKER
Code:
+ RED* - BRN*
DRIVER'S DOOR SPEAKER
Code:
+ GRN/BLK - LT GREEN
LEFT TWEETER
Code:
+ BLU/ORN - GRY/BLU
FRONT PASSENGER'S DOOR SPEAKER
Code:
+ GRN/YEL - GRY*
RIGHT TWEETER
Code:
+ BLK/RED - PNK/BLK
LEFT REAR DOOR SPEAKER
Code:
+ BLU/RED* - BLU/ORN*
RIGHT REAR DOOR SPEAKER
Code:
+ BLU/RED - BLU/ORN
* Wire at speaker is different color than wire at amplifier. Wire at speaker given.
e_lectro is offline Report Bad Post Reply With Quote
First
Second
Third
First
Second
Third
The Honda Civic 20 pin speaker harness only has one rear deck woofer as the Civic only has one woofer. Just wire the rear deck speakers directly to the trunk mounted amp, no reason to run them to the factory harness anyway.
jeff
I am running the rear deck speakers directly to my JL amp, but what I was asking is what wires are the front drivers side woofer? wong05tsx wrote and said the speaker wires were :
When I looked at the 20 pin harness I didn’t even see a yellow wire let alone I couldn’t find the Red/Blu either.
I ran all new wires for the drivers front tweeter, the passenger tweeter, and the passenger tweeter (even managed to get it through the housing going from the car to door). However it was IMPOSSIBLE to get any wire through the drivers side front housing going from the door to the car so I have to find what wires run the front drivers side woofer so I can tap into them at the 20pin connector where you pull it out of the amp,
I actually got very fed up and said f$%k it an ordered the “Honda Integration Adapter
Bypasses the factory amplifier in select 2006-up Hondas” from cructhfield and it will be here tomorrow!
"Wire at speaker is different color than wire at amplifier. Wire at speaker given."
That's probably why you didn't see those colors at the harness end. The wires are different colors at the harness than at the speakers.
Cool! Last question I purchased the below box an I have no clue how to mount it in the trunk? Can anyone give me an exact directions or a kit to use to mount it? Also I need carpet that matches the trunk doesn't anyone have a link for th carpet?
So if I don't plan on using my rear 6x9's then this will work fine? What year civic??? Or a crutchfield link would be great
InFaMouSLink
10-30-2015 09:43 AM
xsilverhawkx
09-28-2015 06:51 PM
