TSX + Navi... soo confused, need advice
Old Nov 10, 2008 | 09:07 PM
dieselstation's Avatar
1. Do i NEED Mercman's harness? What does it do? Is it possible to install 2 amps + sub without it?
2. If i DON'T use mercman's harness, will it affect any other part of the system? like Bluetooth or USASpec ipod or anything else?
3. What upgrade speakers do you recommend if i want to stick with the factory amp? (as in.. just changing speakers.. not adding an amp)
Old Nov 12, 2008 | 12:53 AM
anyone?
Old Nov 12, 2008 | 03:45 PM
White92's Avatar
I don't suppose you HAVE to use his harness. I don't know of any other out there though. I'm using it and don't know what I what have done without it. It basically bypasses the factory amp so you don't have to cut any wires. It terminates into 4 RCA's that you plug into your aftermarket amp.
It will not affect anything else. Your nav and HFL will still work like normal, but louder and more clear depending on what amp and speakers you use.
I can't help you with the last question. I replaced my speakers and amp at the same time. I used the JL-650's up front if it matters. Feel free to PM me if you want.
Old Nov 12, 2008 | 04:03 PM
thanks for the reply. looks like i'll probably have to get merc's harness in order to make it simple. I just wished he's start making them again.
As for components.. What do you think of this setup?
Subwoofer:
JL Audio 10W3V2-2 300Watts @ 2ohm - $130
Sub Amp:
Rockford Fosgate Punch P300-1 300watts @ 2ohm = $140
Multichannel Amp:
Rockford Fosgate Punch P400-4 50watts x 4 @ 4ohm = $149
Front Speakers:
Alpine Type S SPS-600C 6.5" Component 80watts = $85
Rear Speakers"
Alpine Type S SPS-500 5.25" Speakers 55watts = $60
10" sealed sub enclosure = $50
Total = $615 + tax
What do you think?
Old Nov 12, 2008 | 05:27 PM
Jottle's Avatar
Did you get ahold of mercman? Many of us are also looking to buy a harness from him, but he's been gone for some time.
Old Nov 12, 2008 | 06:40 PM
mattastick's Avatar
I'd check out some different rear speakers, if not even the components... The Rockford 4-channel is really underrated... I have a slightly older 450.4 in my car, and it's rated at 60 x 4 channels at 4 ohms... The birthsheet that Rockford sends out with every amp shows 98 x 4 channels at 4 ohms... Fortunately, I've bought Rockford amps before and knew that I'd need a speaker that can handle around 100, and got my Polk/Momo components, and they sound great... As for the sub amp/woofer combo, that looks good.
What I would be concerned with is that the Mercman harness (according to White92) ends in 4 RCA's. With the two amps, you're going to want 6 RCA's (2 sub, 2 front 4 channel, 2 rear 4 channel). Other than that, it looks good...
mlody
Dec 4, 2019 02:11 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
soupi
14
Nov 15, 2015 11:15 AM
ceb
ILX
Sep 27, 2015 10:56 AM
