Low Pass Filter Freq.
Old Dec 30, 2004 | 08:38 PM
glott's Avatar
Just a quick question... Where should my sub amps LPF be set to. The installer left it at like 125 Hz, but that seemed a lil high, I lowered it 80Hz but i feel like im losing some bass. I have two 10s and an alpine amp in a ported box. What does everyone else do??? Thanks
Old Dec 31, 2004 | 01:50 AM
Bass Mechanic's Avatar
80-90 should be fine, if you raise it too much it will pull the soundstage from the front to the rear.
Old Dec 31, 2004 | 01:25 PM
elduderino's Avatar
VP Electricity
80 is fine, but it's always where it sounds good to you - take responsibility.
Is it a switch or a knob? If it's a knob, you can experiment a bit, because the labels don't correspond precisely.
You did lose some volume, but no LOW bass. You might have to bump your output gain a bit to make up for it.
Old Dec 31, 2004 | 05:27 PM
Mega's Avatar
'05 TSX SSM/EB/AT/Nav
It's always a taste thing. In one of my previous vehicles, believe it or not, I set the low pass to 80Hz and the high-pass to 120Hz. Technically this is bad because nothing was set to respond between 80 and 120. However, if I let either set of speakers hit those frequencies, on certain songs, the bass hummed very irritably. I figure the cutoff is not hard, it's a slope, so even with those settings I was still getting those frequencies a little.
Anyway, I said all that to say don't worry so much about what the "proper" setting is, just go with what sounds best. I personally don't like hearing much mid bass from a subwoofer because it hums to much.
Old Jan 4, 2005 | 02:54 PM
jpswanberg's Avatar
really depends on how low your mids can go. a decent 6 1/2 should be able to hit 80 hz, so I have found that to be a good starting point. jps
rcs86
Aug 2, 2016 06:52 PM
LeVeL
Oct 18, 2015 04:19 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
