looking for DIY stereo
Old 03-25-2004 | 10:00 PM
tumas's Avatar
i'm looking for DIY stereo thing. they told me to ask here.
Old 03-25-2004 | 11:34 PM
Iggy's Avatar
Member since FEB? 20 posts? Who is they? Are you kidding? At least tell us you searched and could not find anything. Lie if you have to, but geeeeeeeze.
Old 03-26-2004 | 01:14 AM
tumas's Avatar
they = people in the second generation section. ;]
Old 03-26-2004 | 08:25 AM
AcuraX2's Avatar
That is way to general of a statement. Exactly what do you want to or are looking for?? The more info you can give us, the more we can provide you.
Old 03-26-2004 | 10:50 AM
tumas's Avatar
i am adding 2 subs and an amp using a hi-lo converter.
Old 03-26-2004 | 11:26 AM
AcuraX2's Avatar
And what do you need to know? How to hook it to the factory head unit?
Old 03-26-2004 | 06:27 PM
tumas's Avatar
yup
Old 03-27-2004 | 02:38 PM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
use the search feature above and serach for DIY and adding a sub
there will be colour pictures and everything. What you want to do is take off the rear seat of the car and you will see an aftermarket amp to power the 9" sub in the back of the car. You can take your connections off the stock amp that way you won't have to run cables through out the whole car, just the trunk and rear seat area. Do a search for the seat removal if it doesn't explain it there either. It is a total of 2 bolts (not the seat belt bolts, they can be left in and move the seatbelt around the seat) and the rear seat slides up and out. hope that kind of helps ya - fire me your e-mail address and I will foward you the pict of the amp and the wires spliced and everything. I reccomend getting a low current relay for the amp remote. I have installed the system without a relay (didn't work not enough power) I installed it with a regular relay (not enought power to activate the relay) and finally worked with a small voltage relay from Radioshack (couple bucks). I found the pics while I searched one day if you can't find them PM me I'll foward them to ya. Cheers!
Old 03-28-2004 | 02:01 AM
tumas's Avatar
thanks RF, but i finished my system already =).
Mike734
12-10-2021 02:25 PM
tsx_boy
12-13-2019 09:33 PM
SUPRMN84
10-07-2015 10:46 PM
4drviper
09-23-2015 10:00 PM
scionxb3003
09-22-2015 06:28 PM
