location for the door lock chirp
Old Oct 13, 2002 | 02:34 PM
mp3coupe's Avatar
I went hunting around today for the buzzer that chirps when the lock button is pressed twice. Does anyone happen to know where its located? I popped the hood and locked the hood latch and kept locking the doors. After about 15 minutes i couldn't locate it... Anyone happen to know?
Im looking to add a remote start to my car. I would think the easiest way would be to tap into the output wire for the chirp to start the car. I rather not run wires in my door jams....
thanks
coupe
Old Oct 13, 2002 | 03:55 PM
mp3coupe's Avatar
Nevermind, I found it its located on the passenger side front fender behind the inner wheel well. The buzzer looks huge....
How are the installers, installing remote starts? Which wires are they tapping into for the trigger wire(factory remote).
Im thinking about installing a dual stage shock sensor, Im going to install a diode and prewarn to factory "chirp"
coupe
Old Oct 14, 2002 | 08:39 PM
randomwalk101's Avatar
pls update us on how you do the warn away chirp with factory alarm and dual stage sensor. Currently, most of us have factory alarm with dual stage sensor but only use the high impact to set off the alarm..ei no warn away chirp.
Old Aug 21, 2003 | 03:38 PM
ttran_sf's Avatar
how can i hook a shocker sensor to the existing factory alarm system. And what kind/brand does the shocker sensor be, to work properly with the factory unit?
did you know if you are stilling running your factory alarm system, if someone use a key to unlock the doors, the factory alarm will disable your alarm (which in turn will turn off the shock sensor)
anyway to fix that glitch????
tman570
Jun 11, 2019 07:56 AM
Azonics
Sep 22, 2015 05:28 PM
Sep 17, 2015 10:09 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
