TL: Light blinking on MTX Amp ?
Old May 13, 2010 | 09:09 PM
piggylover1985's Avatar
Anyone has an MTX amp ? I hook up my MTX amp to the car and the "lightning" sign is blinking/flashingand smoke came out from the subs but no sound, anyone knows what is mean ?
I check for ground, power and remote they're all good. Is the amp junk ? I open the amp and not seeing any burn mark in the IC chips,
Old May 14, 2010 | 01:00 PM
thewhitepearl's Avatar
wiring? do the ohms match up?
Old May 14, 2010 | 02:45 PM
It's blinking even without the speaker hook up. Tried it in my buddy's car, since he has a system in it already, and it's doing the samething, but his speakers got push out and stays out, but no sound, looks like it's sending a 12v directly to the speakers, not sure if it suppose to do that. But it got to be something wrong with the amp i think.
Old May 14, 2010 | 09:34 PM
bigdaddyKA8's Avatar
I would check those subs in youur buddy's car too to make sure they're still working... obviously not a fix for your amp but you at least want to know they still work.
Old May 14, 2010 | 09:37 PM
mattastick's Avatar
Grab a DMM and check to make sure the amp is outputing an AC signal. Sounds like the signal is DC rather than AC which is not going to be good and is going to break a lot of things. I would not hook up another speaker to this amp until you can verify what's wrong with it.
Old May 14, 2010 | 11:16 PM
Oh so the output should be AC signal ? I have to check it out, what is wrong if it's putting out DC instead ? Means the amp is junk right ?
Old May 14, 2010 | 11:18 PM
They are still working ok, if we still have them hook up maybe they are toasted by now.
Old May 17, 2010 | 02:05 PM
sorry for asking a dumb question but have u checked the amp fuses?
Old May 17, 2010 | 04:06 PM
Yes, all 3 fuses look good, i even ohm them out with a ohm meter
Old May 23, 2010 | 07:23 PM
Any one knows exactly how many volts needed for the head unit remote wire to turn on the amp ? 12V or less or more ?
Old May 23, 2010 | 09:34 PM
mattastick's Avatar
Should be at least 12v. I've noticed mine seem to be up more in the 14v range though.
Old May 24, 2010 | 06:07 PM
So what to check for at the speaker terminal ? I have a mono amp, i got 68v coming out from the speakers terminal of the amp, i think i have a problem right ?
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
BigJilm
Sep 21, 2015 08:32 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
