LEDS on both doors
Old Mar 22, 2002 | 12:23 PM
BlackACK-CLS's Avatar
Official Member
LEDS on both doors
Does anyone know which wires to tap for the led light? I wanna run a led on the right side. SilverKnight?
Old Mar 23, 2002 | 12:14 AM
SilverKnight's Avatar
Retired. Not available.
Re: LEDS on both doors
I will give you an answer tomorrow .. just got home and it's too late to run out to my car. sorry, bud.
Old Mar 24, 2002 | 10:06 PM
Here it is. The wires are at Driver side fuse box.
Old Apr 2, 2002 | 10:09 AM
NOLACLS's Avatar
Silver..so all you did was tap the two wires on the fuse box and then run the wires to the passenger side door and hook it up to a OEM lock thing like the driver side?? Is it that easy...I dont want to change the light to LED's or anything like that.
Old Apr 2, 2002 | 11:02 PM
Yup. It is that easy. Wiring the wires into the passenger door was a bitch though :P
Old Apr 3, 2002 | 07:55 AM
bl^5's Avatar
Got da Internet Goin Nutz
Silver,
I just moved to Houston and I wanted to get with you on a couple of things. What's the best way to contact you.
Old Apr 3, 2002 | 08:39 AM
NOLACLS's Avatar
You talking about actualy getting the wire from the car cabin to inside the door?? How did you do that...did you run it through the black rubber house with the rest of the wires??
Old Apr 3, 2002 | 05:48 PM
Yup. I can do it a lot faster now since I ran 2 pair of speaker wires in each door.
How? I removed the door but later one I learn to work with cloth hanger and exact placement to get the wires through.
Old Apr 3, 2002 | 05:49 PM
Originally posted by bl^5
Silver,
Give me a call xxx xxx xxxx. The name is Michael ... I need a Do-It-Yourself partner. Are you interested?
Old Apr 5, 2002 | 08:56 AM
NOLACLS's Avatar
Give me a call 281 948 3725. The name is Michael ... I need a Do-It partner. Are you interested?
Just fooling...couldnt resist!!
Ok well I dont think I will be removing the door for this one:shakehd:....so it can be done with a wire hanger...is it real tight for space in there to start the hanger?? I might just have to wait till i get up there for a damn meet.
Old Apr 12, 2002 | 03:09 PM
black bullet's Avatar
To get through door grommets, I use long plastic wire ties. They are more flexible plus they won't puncture like a hanger would or get caught up on things.
Old Apr 19, 2002 | 01:01 PM
4pumpedCL's Avatar
Honkey
if you squirt the wires with some armor-all or similar substance before you run them through the rubber boot in the door they slide through so easy.
soupi
14
Nov 15, 2015 11:15 AM
BIGxRED
Oct 19, 2015 10:47 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
