CL: Kill switch
Old Oct 16, 2009 | 04:47 PM
gnuts's Avatar
3.5 psi
Kill switch
I bought a car alarm that is essentially a kill switch. I need to cut two wires under the hood that would, when cut, stop the car from starting. I was thinking the starter and ignition wire. I did a search and saw a few stickies that describe the location and colour of each wire. The starter wire is black/white and the ignition is black/yellow.
-should i use the starter and ignition wire?
-where are they located?
I have no manual so i'm lost under there...i really need a visual. Thanks in advance.
Old Oct 16, 2009 | 04:53 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
DEI info:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |passenger fuse box *1 |
| POWER UNLOCK|orange |- |passenger fuse box *1 |
| LOCK MOTOR|white/red | |drivers fuse box *2 |
| UNLOCK MOTOR|yellow | |drivers fuse box *2 |
| DISARM DEFEAT|lt. green/red | |passenger MUX module *3 |
| PARKING LIGHTS +|red/black | |passenger kick panel |
| PARKING LIGHTS -|red/yellow | |left of steering column |
| HEADLIGHTS|blue/red |- |left of steering column |
| DOOR TRIGGER|black/white |- |passenger fuse box |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|blue/green |- |drivers fuse box |
| HOOD PIN|yellow |- |passenger fuse box |
|TRNK/HTCH RELEASE|white |+ |passenger MUX module *3 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|blue |- |drivers door key cylinder |
| TACHOMETER|blue | |drivers shock tower *4 |
| SPEED SENSE|blue/white | |cruise control module *5 |
| BRAKE WIRE|white/black |+ |brake switch |
| HORN TRIGGER|lt. green/blue |- |steering column |
| WIPERS|blue & blue/yellow |- |left of steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |drivers window switch |
| RF WINDOW UP/DN|blu/yel - blu/wht |A |RF window switch |
| SUN RF OPN/CLOSE|grn/yel - grn/red |A |relays left of fuse box |
| RADIO 12V|white/yellow |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|white/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |at speaker |
| RF SPEAKER|red/grn - brn/blk | |at speaker |
| LR SPEAKER|blu/yel - gry/wht | |at speaker |
| RR SPEAKER|red/yel - brn/wht | |at speaker |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U. *1 Located in a green 20-pin connector. Use the key switch in the passenger door to test. *2 Located in a green 18-pin connector. *3 The passengers MUX module is located behind the glove box. *4 In a 2-pin connector near the air intake on the drivers side shock tower. *5 The cruise control module is to the right of the steering column.
goodluck,let me know if this helps
Old Oct 16, 2009 | 05:04 PM
gnuts's Avatar
3.5 psi
^ I stated that i found that info already. did you ready my post? I really need a visual, anyone?
Old Oct 16, 2009 | 05:08 PM
just trying to help you out with wiring list I know of.
Old Oct 23, 2009 | 08:30 AM
pimpassacura's Avatar
all you have to cut is the starter wire. and if your also talking about installing the kill switch u want to connect one end to the black/white wire coming from the remote start brain and the other side to ground.
Old Oct 23, 2009 | 01:47 PM
gnuts's Avatar
3.5 psi
I don't have a remote start. I'm putting in a security system which is essentially a kill switch. I'm going to be cutting 2 wires under the hood and if the little device i have on my keychain isn't hooked up, the car doesn't start. The company has a 100% success rate...has never had a vehicle stolen with their device hooked up.
Mike Pilipenko
Mar 26, 2024 09:21 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
eastcoastguy
Sep 23, 2015 06:29 AM
