I've been having problems with my Viper remote start....
Old Feb 3, 2005 | 03:38 PM
alleyesonmeee's Avatar
MIA
Question I've been having problems with my Viper remote start....
The alarm came with my car when I bought it last year, and everything has been working fine up until last month. Today, I went to go remote start my car because I was in a hurry, and it cranked for more than 15 seconds but it wouldn't start. I got in the car and it automatically started the second I put the key all the way in the ignition. I tried it again when I got home and it did the exact same thing.
The only other problems that I have been having with the Viper alarm is that sometimes when I press the lock button to lock my car it will remote start too. Normally remote start is programmed as the lock & unlock buttons pressed together on my remote.
I'd love it if someone could tell me whats wrong with it. Thanks!
Old Feb 3, 2005 | 03:52 PM
elduderino's Avatar
VP Electricity
Is your Viper an alarm/ remote start combo or a separate alarm from start?
Old Feb 3, 2005 | 03:53 PM
MIA
They are seperate. I have seperate modules for everything...remote start, alarm, and two for the window up/down.
Old Feb 3, 2005 | 04:06 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Where did you have it installed?
Is it under warranty?
Old Feb 3, 2005 | 04:10 PM
MIA
I wish I knew...but I didn't have it installed, it came with the car when I bought it used.
Old Feb 3, 2005 | 04:12 PM
elduderino's Avatar
VP Electricity
Well, when you unlock and the remote start triggers, that's probably a power/ground problem. When the voltage drops too low on the alarm, the aux outputs can spike, and that's a symptom (seen it before).
I thought the TL had an OEM immobilizer. The crank-with-no-start sounds like one of the following:
1) The immobilizer is not working. It could be a power problem too, or a ground problem.
2) The ignition wire connection is bad.
3) The power connection for the realy harness is bad. Since this is usually where th installer graps 12V for everything, if that one connection is intermittent or loose, it could cause these problems.
It definitely sounds like it's install-related. On the one hand, you have no install warranty. On the other hand, a lot of Viper shops will take care of you if it's easy.
If you know where it was installed, you might be able to bluff your way on getting it fixed under warranty... but I think you want to pay for a reputable install shop to check it out. If your install was a hack job, you don't want them back in there...
Old Feb 3, 2005 | 05:35 PM
MIA
Thanks! I'll have to bring it in when I go back to New Orleans, I know some people with alarm/audio shops and I'll get it looked at over there. I hope its nothing too $$$ to fix.
Old Feb 3, 2005 | 06:15 PM
ajbent86's Avatar
where'd you get the window up/down? does it work well? easy to install? (i don't mean to hijack your thread, im just curious)
Old Feb 3, 2005 | 06:19 PM
MIA
where it came from or if it is easy to install...It was there when I bought the car used. I haven't had a single problem with it so far.
Old Feb 4, 2005 | 08:29 AM
Bass Mechanic's Avatar
i was gonna say the immobilizer wasnt working and a few other possibilities but eldude beat me to it
Old Feb 4, 2005 | 10:12 AM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
Check ur remote?
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
