Installing subs....w/out remote/trigger wire.
Old Jul 21, 2003 | 09:59 AM
eh!curaplus's Avatar
Team INSPIRE Canada
Question Installing subs....w/out remote/trigger wire.
Nubee Alert!!!
Pls inform..... Need info on how to get around installing a new deck just to get a remote/trigger wire running to my amp. Any way i can get that same signal from any other devices? If it helps you i'm running 2bridged12's with 600w amp (all alpine). Sucks i didn't go witht the JL setup which had the auto detect through the speaker wires. Thanks for the help in advance!
Old Jul 22, 2003 | 11:50 AM
You can allways run your remote wire to your fuse panel and tap into the radio fuse and just use a toggle switch for on and off use.
Old Jul 22, 2003 | 12:24 PM
Dave@SE's Avatar
You can pick up the remote turn on lead at the factory subwoofer amplifier behind the passenger side of the rear seat. The wire you are looking for is ORANGE. OR, you can get a remote turn on trigger that is switched on and off by any signal to any speaker.
Old Jul 22, 2003 | 02:06 PM
Team INSPIRE Canada
Thanks for all you help guys, hopefully this'll be easier than it looks. I still have to install power line to the trunk. Thanks again for the help.
Old Jul 22, 2003 | 02:48 PM
SK2003TypeS's Avatar
What about the RCA cables ? I have an old fosgate sub and amp and looking to do something similar.
Old Jul 22, 2003 | 06:37 PM
Team INSPIRE Canada
SK2003 you can buy this little box thing from Walmart which you can connect to your back factory sub's wiring. then what that box does is relays the music to the RCA plugs included. All you gotta do is split the wiring to your factory sub and just connect it all together. the good thing is this little thing doesn't need power and it lets you plug RCA cables to it. hope it helps.
Old Jul 23, 2003 | 03:39 PM
Team INSPIRE Canada
dave@se, still trying to find that orange wire you were talking about, is it that small little box to the right of the sub? i 'm gonna check it out right now.
Old Jul 23, 2003 | 03:46 PM
No, you need to take the back seat off to find the stock sub amp.
Does any one know what wires in the wire harness are the speaker wires going into the stock amp? Because I want to split my RCAs right from there.
Old Jul 23, 2003 | 04:00 PM
Team INSPIRE Canada
thanks predator, now would you know how to get to the stock amp. i have no i dea how to take the back seat off. i dont even know if the back seat can be folded over like the accord. i've had this tl for 1 wk and i didn't even have a manual with it?
predator, nice lighting, what color's the interior?
Old Jul 24, 2003 | 05:51 PM
First, you need to remove the bolt holding the bottom seats in place. It is located in the crack by where the seat belts connect, behind the drivers seat. Then pull the bottom cushion toward the front of the car, take the seat out and put it on the floor or some place safe. The back seat cushion has bolts on the sides that hold it in place. When those bolts are out you will need to lift straight up on the cushion. The seats have hooks that hold it in place, I found this part to be a b!tch. After that the amp for the stock system is in plain sight, behind the passenger side. From here is where I am stuck, I have the remote wire hooked up but I can't figure out what wires to crimp on my RCAs. I don't want to use a LOC because I read that you get better sound if you split the wire before the amp for the RCAs. Some one please help!!
Oh, and as for the interior those pictures are from my old Acura Legend and the interior was tan. I am in the process of doing that to my TL.
Old Jul 24, 2003 | 09:11 PM
Hmmm...... never mind on my request for help. After writing that post I was inspired to go and try one more time. I got it to work ohhhh yheaa!
~Predator21
Old Jul 25, 2003 | 01:59 AM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
~Predator21
Ok you got it to work that makes your stereo work, what about mine? What wires did you use? the OR is the remote, got it. What is the speaker wires colors that you used to do the install? Please Respond.
Old Jul 25, 2003 | 02:09 AM
Team INSPIRE Canada
residual, im with you on that one!
Predator, pls reply on exactly which one's again did you hook it up to?
remote = orange
left = ? ? ?
right = ? ? ?
anyone got a good link for trunk padding?
predator, on your legend, how did you power up all those lights?
cant be all from the cigarette lighter, am i right?
Old Jul 25, 2003 | 02:22 AM
eh!curaplus
to power up neon lights you can run wires and an in-line fuse straight to a switch and then to your lights. simple as that.
Old Jul 25, 2003 | 04:27 AM
Team INSPIRE Canada
Residualfreedom, have any idea about the laws on lights in T.O?
dont wanna get punked by the 5-0's? if anything that's what'll do to my car, attract attn and lose some luxury, what do u guys think?
Old Jul 25, 2003 | 10:26 AM
I don't know about the laws up here about the neons. I have heard they are illegal for streety use but I have seen them installed many many times ( in the car and under ). I personally don't think a cop will stop you for it unless he is looking for something to pull you over for. I can almost gaurntee he wil give you a warning before a ticket, you should be ok to install them I would make sure you can take them out without any marks (if you have to take them out) i.e. holes, clips or screws. Nothing looks worst than a MOD completed and then removed but it is very obvious someone has tired to do something here.
Old Jul 25, 2003 | 11:20 AM
Team INSPIRE Canada
okay, i finally have the seat off, can someone pls tell me where the god damn amp is, or where the wire is at least. i have the lower back seat off, do i need the top taken off too? pls reply quick, pm me!
Old Jul 25, 2003 | 11:24 AM
Yes you have to take back of the seat off too. you have 3 10 mm bolts and then you have to lift the seat up, it is on hooks. becareful not to scratch the leather.
I hope that helps you and could you tell me the color of wires you use to splice off. please and thankyou
Old Jul 26, 2003 | 04:00 AM
Team INSPIRE Canada
just want to let you guys know......
I DID IT! I DiD iT! i dId It!
i got lost taking out the upper portion of the back seat, spent 10 min trying to take out the initial bolt which i found out later was the wrong one(took out the seatbelt bolt instead)_Pls note, if anyone wants to attempt this in the future, make sure you have an extra long extension bar for your tools or you'll mess up your interior or get leather burns on your fingers. thanks for the help guys. by the way, i ended up running 10 gauge wire from the battery for a 600w alpine amp. is this enough or should i go with the advice of 4 gauge power wire?
Old Jul 26, 2003 | 04:07 AM
Team INSPIRE Canada
Residual, you gotta splice
blue = for remote lead
yellow = i think was the positve
purple = was the negative
*if not switch them over, but im sure it's those three colors.
when spliceing you a/v jacks/wires, there's two layers.
go through the first layer of plastic and wires, then there'll be another set of wires inside which are the ones you gotta connect with the wires form the amp.
i'm in etobicoke, if you want exact details or need a hand just ask and i'll PM you my cell #. Hope it works out like it did for me.
Old Jul 27, 2003 | 06:56 PM
Didi you cut the remote and attach a wire to it and bring that wire to you amp? or did you just TAP on to the remote without cutting it?
Old Jul 27, 2003 | 07:09 PM
Still haven't got it yet. Please PM me your cell or give me a call I have PM'd you my cell #.
Old Jul 29, 2003 | 10:39 AM
Team INSPIRE Canada
if i recall, the blue wire was the wire i tapped into for the remote and the yellow/orange and the purple wires was the ones for the rca. i didn't cut them. all i did was cut the rubber off slowly from a portion in the middle(try not to cut any of the wires inside), wrapped the new wire around the exposed exsisting wire. and electrical taped it all. make sure that the wires that you attach to the exsisting wires are long enough. i had to re-attach my wires 2-3 times cause once it came time to putting the box into it's place, it tugged all the wires out. (really pissed the F*ck outta me) check your PM, i left my number just in case you have any more probs.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
