how much speaker wire.....
Old Oct 13, 2008 | 06:58 PM
nickjames's Avatar
Cocaine is a helluva drug
Wanna route my speakers from an amp in the trunk (unless other suggestions) how much speaker wire will I need??
Old Oct 13, 2008 | 11:36 PM
JerZDevil's Avatar
It depends... How many speakers are you putting in and where do you plan on mounting the amps?
I replaced my fronts with components. I did 15ft each Tweeter in the dash and 10ft for each mid in the doors. The wires reached all the way to the trunk/bumper when run/tucked into place.
If you are doing the rears you will probably need about 5' each speaker.
75ft is good with more to spare in case you want to replace the center.
Old Oct 14, 2008 | 10:22 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
What kind of car?
Old Oct 14, 2008 | 10:49 AM
nf3d0149ab's Avatar
I like the idea Wong05tsx had with running string from what area to what area, measuring that length, then adding a foot or two.
Seems like a straight-forward logical way to measure speaker wire.
Good luck man.
Old Oct 14, 2008 | 12:24 PM
wong05tsx's Avatar
Need more room in
Noah
+1 on Jerzdevel - 75ft is safe + spare
you should be fine with 50-60, though, if you have a coupe maybe even 30-40
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
