how in the hell? power cable
Old Feb 5, 2002 | 11:04 AM
jyang411's Avatar
I've been trying for the past 2 hours or so... to push the power cable for my amp through the rubber grommet..and it is NOT working at all... that hole is soo tight, i've gone through pain trying to push it through.. bending my fingers and tearing up my knuckles...
anyone have another method? or a cheaters way to get the 4-gauge wire through to underneath the driverside dash?
need help badly! thanks,
jyang411
Old Feb 5, 2002 | 11:16 AM
StreetEffectz's Avatar
Did you pop the middle piece out of the grommet? It's pretty easy to slide it through.
Old Feb 5, 2002 | 11:42 AM
jyang411's Avatar
how do you slide it through?
am i supposed to twist the middle piece? and should i pool toward the front of the car..or push towards the back..
i think alot of my difficulty has to do with the manuverability of my hands...
i know the subs will be great once i get this power cable through..
more help would be appreciated again. thanks..
-jyang411
Old Feb 5, 2002 | 01:50 PM
Brewboy's Avatar
I carefully cut a small hole in the side of the rubber grommet/boot to slide the wire thru. May also cut the wire at a diagonal to form a small point may help. Use a small amount of liquid dish soap on the wire end to make pulling easier. I pushed the wire to the engine bay from cabin. Good luck.
Old Feb 5, 2002 | 02:19 PM
systek's Avatar
this is what i did too...that grommet that the large factory harness goes through has alot of room to be cut again, just do it carefully, and my 2awg pwr wire fit just fine
Old Feb 5, 2002 | 03:25 PM
Austin519's Avatar
jyang411:
"I've been trying for the past 2 hours or so... to push the power cable for my amp through the rubber grommet..and it is NOT working at all... that hole is soo tight, i've gone through pain trying to push it through.. bending my fingers and tearing up my knuckles... "
Ha ha ha pitiful!!! Just pitiful!! I give you the cable...and you can't get it through the grommet!!! Nah I'm kidding man. You can drop by my place and I'll do it...but all you do is use a little soap and water...or WD40, but preferably soap and water...or hey I've even used Sex Wax...and then just push it on through. Just remember Jason, when you're trying to push a thick thing through a small hole and the hole is too tight, try using lubricant
Austin519
Old Feb 5, 2002 | 07:38 PM
Lightbulb
Use silicone lubricant instead of messy dish soap that will get inside your dash. A small cut in the rubber boot/grommet will work.
Old Feb 5, 2002 | 09:08 PM
Austin519's Avatar
TL Daddy:
That messy soapy water dries...while silicone lube not only doesn't dry, but also attracts nasty dust and dirt...and looks like a nasty hairball a few months later.
Austin519
Old Feb 5, 2002 | 09:39 PM
I didn't have that problem - just don't use that much, just on the tip.
Old Feb 5, 2002 | 10:01 PM
Austin519's Avatar
TLDaddy:
Water based lubricant is always easier to clean up than silicone Heh heh heh...
Austin519
Old Feb 6, 2002 | 04:18 AM
jyang411's Avatar
FINALLY!
It's all hooked up and I just rolled around the block and a lil of austin.. I must thank Austin519 for all his help... not sure I coulda done it without him. Though he did knock my door with my neighbors' car...
anyhow... i like the new sound..and everything else..including backseats are in place... I left some of the screws out tho..(couldn't fit 'em back..and couldn't reach that far back)
I'll let you guys know what I think once i've had them in for a few days.
-jyang411
Old Feb 6, 2002 | 04:36 AM
Austin519's Avatar
jyang411:
Ah...4:18 AM...so you got it in 14 mins ago eh? Heh heh...finally got your remote wire done? Yeah that grommet is a total b|tch...Ford's got it down...4 grommets spaced out from the floor the the rear of the dash...Acura? 2 grommets, barely accessible.
Oh and
"Though he did knock my door with my neighbors' car... "
You failed to mention the stupid girl interlocked her door with yours while I was upside down looking up under your dash, and I came up and pulled your door to before I realized what the idiot had done Don't go giving me a bad name now jyang411, I spent 2.5 hours on your lazy butt for free
Austin519
Old Feb 6, 2002 | 07:20 PM
Re: FINALLY!
-jyang411
That's why you're supposed to put the seat backrest on before you replace the seat bottom, so you can replace the bolts.
Old Feb 7, 2002 | 03:49 AM
jyang411's Avatar
I did...
I did replace the backrest first.... in opposite order as i removed them...
I couldn't fit the most left screw in... the other one... i just can't deal with because it's inbetween the seats.
it's sitting there now... if i get bored enough i'll put it in.
Old Feb 8, 2002 | 10:36 AM
dnd2984's Avatar
Why do you need to take the back seat out I am gonna install a sound system and I need all the help I can get.
Old Feb 8, 2002 | 12:35 PM
Kam
lets us know how is sounds when your'e done
Old Feb 9, 2002 | 06:56 PM
jyang411's Avatar
The subs sound great!
Now that I completed the install, the subs power for hmm.. 20 minutes then the amp shuts off.. bleh.. i guess i'm going to have to give this amp back to a friend... and save up for better stuff.. rockford fosgate,... or possibly phoenix gold.
You have to remove the rear seat to access the rear stock Bose amp. By splicing the blue wire, you can get a remote signal to your new amp. Also, by taking out the rear seat, it's much easier to run power cable to your trunk by threading it from the side up and then through the metal to the trunk.
It only takes hmm.. 20 minutes to take out the rear seat?.. it's a cinch..so don't be bothered by task..
jyang411
time to save for a new amp.. =DDD
Old Feb 10, 2002 | 05:08 AM
Austin519's Avatar
jyang411:
Let me know man...you know I'll hook you up for my cost
Austin519
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
DerrickW
Nov 15, 2015 05:52 PM
ValdezQ26
Oct 1, 2015 04:48 PM
