CL: how do you have your wires ran?
Old May 26, 2009 | 04:47 PM
on1wheel01's Avatar
well guys just got my 1/0 power wire in. currently I have my 4 gauge ran on the left side with remote. and on right I have the rca's on the right. the problem is there is almost no way to get this stuff tucked in the sides. I plan on keeping the 4 gauge for the neg from front to back batt which I will turn to 1/0 for ground when I gets more money. so maybe pull the seats and run it down the middle or maybe move the ground to the rt side with rca's and try to squeeze the 1/0 on the left. thoughts suggestions
Old May 26, 2009 | 05:44 PM
mattastick's Avatar
In conduit under the car. On the driver's side, there's a plastic piece about 1-2' from the outside of the car that you can zip-tie conduit to. Get some of the gray exterior air conditioning conduit, feed the wire through, and zip-tie it to the plastic piece that covers the brake lines (i think).
Old May 26, 2009 | 07:59 PM
Steven Kephart's Avatar
I was actually happy with the ammount of room under the carpet down the drivers side. I tucked my 2 awg in there without any issues.
For ground, just attach it to the chassis. Just make sure you have a good connection to bare metal and you will be fine. I prefer to run bolts through for grounds on my own vehicle.
Old May 26, 2009 | 08:30 PM
D.Greenwood13's Avatar
2000 WDP
I would go with what Matt said, best thing to do!
Old May 26, 2009 | 09:05 PM
on1wheel01's Avatar
yea that be be the one I go with will see tomorrow yea I'm still gonna run a neg from batt to batt read that it is the best to do
Old May 26, 2009 | 09:44 PM
mattastick's Avatar
Good call with the - to -. I wish I had enough wire to do it. Wire running between the batts is going to be less resistance than running through the steel of the chassis.
Old May 26, 2009 | 10:31 PM
I've seen it argued both ways and I'm not convinced that a separate run is best. Technically the chassis steel would be a much larger conductor than even the 1/0 awg wire. That is unless the welds within the chassis are poor which shouldn't be a problem. And of course you want to be sure your big three are done so there are no weak links in the chain. But a separate run could never hurt, except for maybe the wallet.
Old May 26, 2009 | 10:42 PM
mattastick's Avatar
While this is true of 1 negative run, it is most certainly beneficial if you do multiple runs of negative to negative. For example, it was recommended in a thread on another forum about how to get the loudest Street A car in North America that one should do 7 runs of 1/0 for each power and ground. That is 14 total runs of 1/0 throughout the car. And this is for a car with 1 battery and 1 amp. Obviously this is stupid overkill for most daily applications, but the more wire you're able to run, the shorter/better the flow will be between the negative grounding posts of the less voltage drop you'll have over the distance. Less voltage drop means more power.
Old May 26, 2009 | 11:15 PM
on1wheel01's Avatar
yea also I'm gonna use the regular grounds to and I just picked up 7' of extra knu wire for 15 shipped killer deal just gotta get some 1/0 connectors thought about making them from copper pipe to do my big 3 in 1/0 and maybe sell the 4 that its done in now.
Old May 27, 2009 | 08:51 AM
2000 WDP
G.L. bro keep us posted!
Old May 27, 2009 | 02:21 PM
on1wheel01's Avatar
well I just ran the 1/0 power wire it actually wasn't that bad it fit on the left side where the 4 was. I'm just gonna have to take loose the back panel right at the seat to fit it in there and ill have to figure out where to run the 4 gauge on the right side through the fire wall. its pretty cramped there. so maybe ill run it through with with the 1/0 and just bring it behind the radio and all along the inside of fire wall to the right side.
Old May 27, 2009 | 03:04 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
under the carpet is your best bet
Old May 28, 2009 | 12:18 AM
mitch14's Avatar
CL in lawnmower status
yeah, i dunno why ppl think it won't fit under the carpet, it's super easy, and a lot of room
my 1/0 fit fine under there, you would probably even fit two runs down there and it would be fine, mine runs down the right side btw, so i might have more room there.
and did you say you were running a ground under the carpet, shouldn't you keep the ground cable as short as possible?
Old May 28, 2009 | 12:45 AM
on1wheel01's Avatar
well yes short gounds are good , but it's also good to ground each batt to the other. and i also have the reg grounds in place
this explains more and is what im doin http://www.caraudio.com/forum/showthread.php?t=398527
Old May 28, 2009 | 12:19 PM
'03TL-S's Avatar
So is it okay if i wire my red top to a kinetic battery using 1/0?
Old May 28, 2009 | 01:16 PM
on1wheel01's Avatar
thread jack lol but yea don't use anything smaller than 1/0 for connecting batts.
Old May 28, 2009 | 07:36 PM
'03TL-S's Avatar
lol my bad man. i was just reading that thread and the poster said to not use different batteries and i was concerned so i had to ask.
Old May 28, 2009 | 08:37 PM
on1wheel01's Avatar
lol it's ok. I wouldnt see a problem in mixing those batts.
acuratl26
Apr 23, 2020 07:30 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
mars
Sep 28, 2015 11:03 AM
